AC recharge: Help needed
http://answers.yahoo.com/question/in...3091209AAy1zBq
Decent description of where it is. (the hose only fits on one of two nozzles, so you really can't screw it up TOO badly unless you overcharge it)
If you hit a curb and put a gash in your tire would you connect an air hose to it and expect it to inflate?
No, you wouldn't because it's obvious that the air leaked out of the gaping hole.
So,,, knowing you have a leak in your AC system why would you put a $30 +/- can of refrigerant in it?
Put the **** in the car or just blow it into the air, same end result.
It's your money waste it as you will you ******* retard.
It's the ******* black thumb cap on the accumulator, the accumulator is the aluminum can with AC hoses connected to it.
Thanks I'll keep that in mind.
Just a thought.
Heres a pic of when I did my AC, this was during the evacuation, the yellow hose is connected to the low side access fitting.
Maybe he does, maybe he doesn't. How do you guys know he does?
If it's a 2002 on the factory fill, couldn't it just need recharging?
Just a thought.
I always use the flat tire example, same here. If you went to your car and found a flat tire do you think the air just disappeared? Fill it up and you're good to go for a few more years?
I am an HVAC/R tech, I've worked on everything from little reach in refrigerators to systems for skyscrapers. I am EPA universally certified to handle all types of refrigerants, and I have handled at least 20 different types.
Refrigerant will last forever, literally forever in an AC system. It never disappears, never changes state, never wears out as long as the system doesn't have a mechanical or electrical failure. It will remain as it was when it was new, literally until the world ends.
If your refrigerant is gone, theres a leak. If it's gone and there is not a leak then someone has let it out.
I'm kind of sick of the no cold air = add refrigerant attitude people have.
The OP asked where to connect the hose, I focused on why he's adding refrigerant. There are hundreds of reasons why his AC is not blowing cold, but he only asked where to connect the line. I tried offering advice to diagnose it, was called a smartass.
**** it.
He could very well have a full refrigerant charge already, and it's not blowing cold for other reasons.
I'm doing this for free, on the other end of my computer free advice is worth the price whether it was asked for or not.
On my end of the computer I'm spending my time and getting nothing, well getting called a smartass.
So **** it. Have fun working on your AC
**** it.
You should know it's not easy to contain a gas PERFECTLY and INDEFINITELY, and I doubt GM at least has accomplished THAT in our F-body's. A 10 year old AC system might have lost the refrigerant out of seals in the system... If you could fill that up and last another ten years, I PERSONALLY would not consider that a leak worth repairing, unless I like blowing money. The OP should inspect for a significant leak of course, or oil around the compressor etc. Of course I wouldn't use the cans either. I'd take it to someone (like you) with the right tools and the machine to evacuate the system properly (not into the air) and fill it correctly and change the orifice tube, inspect/change/clean the condenser, etc... At this point possible leaks, significant leaks, should be looked for and addressed... Of course the OP has a leak, but to what degree? That's all I meant... Some of you were talking as if you KNEW he had a really bad leak or something... I guess I misunderstood. NO PROBLEM.
No one's not appreciating your expertise... That's welcome... But you do come off like a smartass, and if it seems to be a show of ingratitude to you that people call you out on it, then stop helping people... There are other users here that can offer the same help you would and do it politely. We're all here to chat and have good time... You're getting free advice as well, whether you asked for it or not. You should take it.
Here, this was unnecessary:
My point about the tire...see how in depth you went with your explaination about tire air.
Thats why I use it as an example, it's obvious, you know it, you never went to 'tire school', it's easy to understand.
If I used technical terms about AC stuff no one would get it.
And just FYI evacuation of an AC system is done to an empty system, it's done to pull a vacuum and remove non condensibles. You were refering to recovery. Recovery is the process of taking refrigerant out.
I don't know how to type and not come off as a smartass so I hope this doesn't offend you.
Maybe the site should incorperate something like the trader rating, except a sensitivity rating for each user. This way people can either type raw text without emotion, straight facts. Or in the case of a more sensitive user, type kind words more bullshit, and pampering of emotions. Just an idea.
I'm doing this for free, on the other end of my computer free advice is worth the price whether it was asked for or not...
More unnecessary than your replies (by your own admission) of advice to posters here are the replies of advice to YOU that you come across as a smartass without any provocation... Now those are unnecessary. You're obviously not going to listen anyway. But you gotta give me credit for trying... People will keep adding refrigerant to leaking systems with no need, and people will keep feeling better about themselves by putting other people down... Such is life, huh?
And if this comment gets me banned I'll be posting the same way when I come back.
Right now I'm going go argue with my tire, it'll probably be about as intellectual an arguement as this one.
