i messed up!
also i did search but didnt find and clear cut advice.
They should read just fine. You just put in a different overlay, right? Why would they read incorrectly? They're all electrically activated.
When I put that cluster back in everything sets up properly. Speed and rpm go to zero, volts go up to wherever they need to be and fuel goes where it needs to be.
So why not install your cluster with the front clear plastic off, turn the key on, then put the needles back on.
