factory alarm issue-keeps going off
hey guys. on my 00 camaro the factory alarm will start going off about 5 sec after i set it. just started happeniong today. Ill hit the lock key on the remote, it will lock and set alarm then about 5 sec later alarm will start to go off. was wondering if anyone else has had this issue or if i am just over looking something really simple.
Thanks
Thanks
hey, i figured out what my problem was, turned out to be the shock sensor for the alarm. Its located behind the interior panel where the spare tire is. I umpluged it and dont have the issue anymore. Im just going to leave it unpluged till i fine another one to replace it with but thr rest of the alarm system still works fine with it unpluged.
Its worth a shot to check it out on your car to man, goodluck.
Yep those sensors go funny sometimes.
Easy way to test them. The little red light should be OFF then when tapping the sensor it should turn on for a second or two then back off. If it doesn't (like it is always ON, or some people have had them work backwards), then it is definitely bad.
One thing you can try is adjust the little **** and see if it has any effect. I did notice that mine will sometimes get grumpy if there is water on the hatch and I open it too quick, letting water run down there. Sensor gets wet then goes wacky until it dries out.
dam we all have this issue.first time i got cought in the rain in my ws6 and that night my alarm started going off to.i went out side with my 9mm looking for someone.reset the alarm and it went off again scared the **** out of me lol.im going to unplug my sensor and see if mine needs dryed out.
its in your book.something to do with the radio fuse.i just unplugged mine and it didnt go off any more.ill pluge it back up to see it it goes off again.so far unplugging it worked.
My alarm always goes nuts.
It's not the shock sensor, so I disabled it EXACTLY as per the instructions in the owners manual. Tried this repeatedly, and it still goes off.
I'm sure the BCM is screwed up, so now I just slide the door locks back manually. Like the cave men used to do it.
