frozen blinker issue..
the right signal works fine
the hazards also work fine
what do i do?, this is brand new problem, just started doing it tonight
Or it could be a bulb.
Yes but I have had just one side not work and when I replaced the relay both worked again.. Then I broke the lever and had to replace the lever itself.....3 times actually....The relay has a double element doesn't it?? like some lights?? Look at the bottom of the lights that do both, some have 2 bumps some have one bump.... I know the relay for the "4 way" flasher is different as well. Try putting 4 way lights on, that's the best way to find a "blinker bulb out" in my experience...
This was on a 3rd gen, not a 4th gen I'm still assuming they are the same....
http://www.lltek.com/PRS_bin/prs_110...n_Wedge_xx.jpg
Bulb on the left double element "old type"
http://www.worldimpex.com/assets/partimages/043633.jpg
single element....
