oil change light?
Old 02-13-2010, 10:33 AM
senicalj4579's Avatar
Default oil change light?
sounds like a stupid qustion but idk.......why would my change oil light come on if i changed it 1500 miles ago? i used synthetic and the oil is at the proper level
Old 02-13-2010, 11:09 AM
DoubleTapDrew's Avatar
My camaro doesn't have that but my truck does. Usually those just measure how many miles you've gone since the oil change light was last reset, rather than monitoring the actual oil's properties. Your manual should show how to reset it.
Old 02-13-2010, 11:10 AM
eseibel67's Avatar
Did you reset it 1500 miles ago?
Old 02-13-2010, 11:38 AM
i didnt know you can reset those. My trip says 200 miles
Old 02-13-2010, 11:51 AM
peterlawl84's Avatar
its not simply just pushing the trip reset....I believe the key has to be turned to the "on" position and then hold the trip reset button down for about 15 seconds. The change oil light will then flash letting you know its reset.
Old 02-13-2010, 11:59 AM
ok ill look at that.
the oil light only stays on untill the car warms up does that matter?
Old 02-13-2010, 12:54 PM
Mr CHI's Avatar
Whenever you change your oil you have to reset the gauge or the light will come on.
Turn the key,(not starting the car) hold the trip meter button down for 10 seconds.
Old 02-13-2010, 04:11 PM
yup i did that and it didnt come on anymore.
Old 02-15-2010, 01:06 PM
slowpoke96z28's Avatar
thats what is does when the oil life monitor calculates its time for an oil change. if it gets ignored, eventually it will stay on the entire time the engine is running.
