AC recharge question, just refill and good to go??
Old 03-10-2010, 02:43 PM
Searching4Sierra's Avatar
Default AC recharge question, just refill and good to go??
Ok about a year ago i replaced my radiator and in doing so i bent one of the ac lines and you could hear the system lose all pressure.
If i fix the leaking part and just buy one of those refill kits will i be set? Or is there something else i should do too? Again i have not ran the ac for a year now. thanks
Old 03-10-2010, 03:32 PM
fleetmgr's Avatar
No, you need to have the system evacuated first, and then charged. In fact, at this point it would probably be a good idea to have the system flushed to get the dirt and moisture out.
Old 03-10-2010, 03:37 PM
DomesticDisturbance's Avatar
have it hooked to a machine that way they can pull a vacuum on the system to make sure there isnt any leaks in it.
Old 03-10-2010, 03:45 PM
Any idea how much that would cost?
Old 03-10-2010, 03:54 PM
it all ranges from place to place. call around to local shops and see how much it would cost for them to charge it up. i know here at my dealership it cost $45 for labor plus the R134 so it varies
Old 03-10-2010, 04:00 PM
samson_420's Avatar
You will need to replace the hose, replace the desicant(receiver/dryer) and the TXV tube. . . .
Old 03-10-2010, 04:21 PM
i know where the dryer is, but where is the txv tube?
Old 03-10-2010, 06:21 PM
and why do i need to replace the dryer?
Old 03-10-2010, 06:27 PM
eseibel67's Avatar
The dryer has a dessicant bag inside that absorbs moisture. If your system has been open for a year, you have moisture in the system and the bag is useless. You need a new one.
Old 03-11-2010, 04:43 PM
Crazy Z28's Avatar
Can you put the dryer in the oven at low temp to "recharge" or dry the desiccant pack back out? I've heard of people doing this with their desiccant packs used in gun safes. Just a thought
Old 03-11-2010, 05:56 PM
O2Form's Avatar
Why not? but i wouldn't put it your home oven or a welding rod oven because of the oil. Its probably worth buying a new one anyway. The desicant bags get rotted with age and start to fall apart. Then it ruins the compressor. Best just to get new.
Old 03-11-2010, 06:15 PM
my plan is to run a vacuum on the system then refill it, anyone know how much 134 to put in?
Old 03-11-2010, 07:09 PM
fleetmgr's Avatar
You could, but you'll have to destroy the metal shell to get at the dessicant. It's not made to come apart.
If you do manage to figure out a way to get the dessicant out, in the oven at 200 degrees for an hour.
Old 03-11-2010, 07:11 PM
fleetmgr's Avatar
There's a sticker under the hood that'll tell you.
Old 03-11-2010, 07:16 PM
Thanks
Old 03-11-2010, 07:37 PM
Ok i just went to look....i think my sticker is missing
Old 03-11-2010, 08:05 PM
samson_420's Avatar
1.5 Lbs. as far as I remember. . . .
Don't try any of this VooDoo BS. . . . You can if you don't want your AC to blow cold.
Old 03-11-2010, 09:47 PM
O2Form's Avatar
You wouldn't need to pull it out...with the hose off the car its wide open!
Old 03-12-2010, 05:55 AM
fleetmgr's Avatar
Very true, but as the dessicant is inside something you won't get all the moisture out, either. You'd have to rig something to blow through it.
Old 03-12-2010, 07:03 AM
Crazy Z28's Avatar
Lol, I was just thinking out loud guys. In theory it could be done but you are probably better off just buying a new one.
Quick Reply: AC recharge question, just refill and good to go??
