exhaust smell when WOT?
Old 03-15-2010, 05:09 PM
Rgomez1787's Avatar
Default exhaust smell when WOT?
I have a 99 camaro ss with intake and flowmaster muffler. Everything else is factory. The other night i decided to give it some gas and could smell exhaust in the car right when i floored it. There is no sound of an exhaust leak. What can it be?
Old 03-15-2010, 05:19 PM
biggb1783's Avatar
you did this while sitting still, or you were driving along and floored it???
Old 03-15-2010, 05:20 PM
Rgomez1787's Avatar
i was on the highway when i floored it at about 60mph when i smelled it.
Old 03-15-2010, 05:33 PM
biggb1783's Avatar
are you still smelling it now or was it just a one time thing. It is hard to diagnose this concern with no other concerns to go with it. I would regard it as a "hiccup" until you can reproduce at will. you should not be smelling raw fuel from the exhaust.Even sitting still you shouldnt smell raw fuel. At 60 mph you shouldnt smell anything unless there is a major problem. Is it a possibilty that someone around or in front of you floored it as well?? Just trying to justify why you would have this occur.
Old 03-15-2010, 05:36 PM
Rgomez1787's Avatar
there was no one else on the road. Basically it smelled like if my exhaust was pointing into my car. I havent hit the gas since then so i dont know if it does it again. I was thinking maybe a lose EGR? But like i said there is no ticking from an exhaust leak.
Old 03-15-2010, 05:52 PM
biggb1783's Avatar
How often do drive the vehicle, If you do not drive it often it is possible that you "blew it out" by that i mean flooring it could have un seated some build up that occurs from not "DRIVING" it hard - you know what i mean. I do not have an explanation for the smell with out there being an exhaust leak or hiccup or backfire through the intake plenum.
g/l.
Old 03-15-2010, 05:56 PM
Rgomez1787's Avatar
its my daily driver. i basically baby it for the most part. there was no and are no back fires or hiccups. It idles fine and drives fine. It has me pretty stumped and dont know if to ignore it or address it aggressively.
Old 03-15-2010, 06:11 PM
biggb1783's Avatar
That makes two of us.
Old 03-15-2010, 06:55 PM
Rgomez1787's Avatar
i was talking to my pops about it he thinks it might be a clogged cat?
Old 03-15-2010, 07:03 PM
jgoo's Avatar
Idk you would know if your cat was clogged, I would try and duplicate what happened were your windows down?
