Replaced Idler pulley & still squealing and chirping!!!!!
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
Ive started having a chirping and squealing noise at idle and gets louder as the RPMs climb while driving.... As stated ive replaced the idler pulley and its still doing it..... Do I need to replace the harmonic balancer??? it sounds as if the noise is coming from around that area.... This noise is so damn frustrating and its becoming embarrassing when im driving.... please help!
It could be your AC idler pullies. Rather then buy each one, try this as a quick band aid and find out which one it is:
https://ls1tech.com/forums/general-m...l#post12947844
Harmonic balancer is the very last thing i would look to. Most likely the AC tensioner or idler or belt. Then the other idler then stuff like the alternator or power steering.
Well i took the belt off and spun the pulleys with no weird sound coming from any of them... Its def coming from the drivers side & thats why I replaced the idler pulley down there..... Any other tips?
How many miles are on the car? Have you ever changed the belts? Look at the main serpentine tensioner and see if the marks on the tensioner are within spec. Does the belt seem to have sufficient tension? Your description sounds like a slipping belt.
ok im going to look at the a/c tensioner next..... How do I take that off? What tools are needed?
Also, is this the right part that needs to be replaced? http://shop.advanceautoparts.com/web...S_560864597___
To save some time/guessing cash, take off the main belt and run the engine for a few seconds to find the sound. If the sound is still there then its the ac. If not then its something else. BTW I have a less than 3k mile whole tensioner setup for the ac ill sell for basically shipping/gas to the post office if you need it.
Thats a good idea man, thanks for the heads up with that.... & if the noise is still there ill def take your offer on the tensioner. Thanks for helping me out & hopefully ill find the culprit soon... Its serioulsy embarrassing driving with this squealing
UPDATE..........
Just pulled off the belt to see if it was still squeaking and sure enough it is.
What should I look into replacing since its not the a/c tensioner?
Thanks!
Thanks!
You took off the A/C belt and started the car? Try the main tensioner pulley. I replaced both the tensioner and idler pulley, only to find out it was something on my A/C drive. But if it's still making the noise with the A/C belt off the car, then it might be one of those 2 on the main belt. Also replace the belt itself...
NO i took off the main belt and the squeaking stopped..... Ive replaced the idler pulley.... Im at a loss and dont know where to look... It still sounds like its coming from that area too
