clutch to the floor, loud clunking noises help! (update)
i was driving today and i did a quick, not very strong pull shifting at around 4k rpm, from 2nd to 3rd to 4th letting off at around 70-80...next time i start my 93z 134k (2-3k on clutch)...when i push the clutch all the way to the floor to put it in first i hear this clunking sound..ONLY when the clutch is all the way to the floor "clunk clunk clunk clunk clunk clunk" and i can feel it in the pedal too...
what the hell is goin on! i wasnt driving it THAT hard surely i didnt break anything... did i push the clutch in too hard and knock something out of adjustment like the stop for the clutch pedal or somethin?... id appreciate any input on what is clunking!!
check the hydraulic fluid reservoir, little tiny thing behind your driver hood strut, and flush the fluid if you've never done it, or fill if low. i flush mine every 3-4 months. should be a write up on here... try that for starters, but sounds like it could be more...
(im guessing these are pilot bearing/bushings?) when me and my uncle pulled the tranny because the throwout bearing shattered on me we replaced the clutch/pressure plate also (didnt need to only had about 10k miles but we did anyways), he was rushing the **** out of everything and i noticed these 2 bearing/bushing we didnt use when i got back home. but since the throwout bearing blew on me before im guessing the owner before me didnt replace it or the pilot bearing...could this be the problem?
the previous owner replaced the master and slave when he did the clutch job so it has about 10k on it i dunno if its adjustable or not...and honestly, i didnt know much about anything goin on i was new to all this when me and my uncle pulled the tranny, i dont think the shaft was messed up...and i realize now he didnt say anything about the pilot bearing because i hear its a bitch to remove and he was rushing everything
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
well that could be the reason the throwout bearing shattered on me in the first place and maybe causing this...how do i check if its an adjustable one and adjust it?
take the bottom panel of the dash off, its like 4 screws, and look at the rod that connects to the clutch pedal. if its threaded, or looks like it can be lengthened in any way, its adjustable. Some people retrofit the stock one to be adjustable, some people buy aftermarket adjustables ones like the Tick.
ok i just checked i couldnt see or feel any threads or anything to adjust it by...i also noticed when the car is off and i begin to push the clutch in i can hear squeaking kinda like a door on a old house coming from under neath the car (where the slave pushes on the fork im guessing) i dunno if thats normal, i cant tell if its doing it with the engine on cuz exhaust is to loud
i just pulled the slave off the trans in the off chance i might find some pieces of metal or a bent fork...didnt find anything except that the fork that disengages the clutch seems to rattle around alot but im not sure if thats normal
something is obviously loose or not turning concentric. Perhaps your pilot bearing is shot. when the clutch is engaged, the input shaft is held in place by the clutch disc, but when you push in the clutch, the only thing to support the input shaft now is the pilot bearing.
idk man, if it doesnt look external, about the only thing you can do is pull the trans back off. Sounds like you have a major problem, or something is loose somewhere.
ya i know i gotta pull it i was just hoping it wasnt internal
i think u maybe be right about the pilot bearing...its the only thing we didnt replace...somethin so small ***** everything up lol
i appreciate the help man
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
i read the title of this thread "clutch on the floor..." and couldn't help but think of the song "pants on the ground..."
clutch on the floor, clutch on the floor, lookin' like a fool with your loud clunkin' noises, help!
i finally got my car to a good guy at a shop...he says its the throwout bearing (again) making all that racket, the ring that holds it onto the fork is about to give out, which it did do last time about 2000miles ago...
i dont understand why this is happening again! i bought the car almost a year ago and the guy recently replaced the clutch and all that, think it had 2k on it when i got it, then i put about 6k on it and the throwout bearing ring shattered...so we replace the clutch PP and T-bearing, 2k miles later its givin me ****...is it a bad clutch fork??
one of the selling points for me buying this car was a recent clutch job...now ive dropped the tranny twice in less then a year...oh the irony...
