Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- Camaro and Firebird: How to Change Power Steering Fluid
Step by step instructions for do-it-yourself repairs
Power Steering Cooling Success
#301
LS1Tech Administrator
Received 1,793 Likes
The hose supplied with your new cooler might have been 11/32", which is just fractionally smaller than 3/8" and might explain why you can't get it on all the way.
#302
The hose that came with my cooler was 11/32", and fit extremely tight. The hoses on the car from the factory are 3/8". Get new 3/8" heater hose from a parts store. It will fit much better.
#303
I'm sure it's not either of those. I haven't taken it apart yet, but it visually appears to be 3/8". It's not big enough for 1/2 or 5/8 inch.
Thanks guys.
#304
#305
Well, got the new hose on with little problem. That extra 1/8 of an in helps. Bled the PS system, but now my PS fluid looks something like shaken up orange juice ... Not sure what the issue is? Water mixed in with the fluid maybe?
#306
Sounds like some coolant got into the PS fluid before you removed the stock cooler.
#307
It's not mine! woo hoo!
While replacing the pressure hose I searched how to flush the power steering system. Of course I came across this thread and convinced myself I should just do this mod before my "heat exchanger" craps out (and since I need to flush the system anyway).
I ordered the Derale 13200 so I can mount it to the radiator (that 13224 is pretty slick, though!). I went with an ACDelco 26347X '99 Z28 upper radiator hose. I'll post pictures once I get it installed.
#309
^ This is nice and looks sturdy. I've been having a bitch of a time lately with my Perma Cool unit as any little bump and the fins bend. (Straightening them back out is not fun.)
It looks like this heat sink design is really sturdy and that Derale is also putting their finned units out with an end protector, which is really nice. I wish I had one!
#310
I decided to go with the heat sink design because it's what a lot of the offroading guys use. Since rock crawling is a very slow pace resulting in little air flow, they use the heat sink for better cooling.
#311
So my car has a production date of 3/99 and I was looking under the hood and the upper radiator is just a one piece hose. this means my car is not equipped w the PS cooler from the factory?
#312
Well your user name is "99SS", so I'm guessing the car is an SS. If so, then it did come from the factory with a cooler, unless it's not an original SS car. Someone might have simply removed it and replaced the hose with a non-cooler one.
#314
Ah, well in that case then yes, your '99 Z28 would not have come from the factory with any power steering cooler, so it's still in it's original configuration.
#316
So.... I don't know what I was thinking or looking at when I thought I would be able to easily mount the cooler on the front of the radiator (which is why I went with a Derale 13200). I had no place to route the hoses without hacking stuff up -- so down to the radiator support like everyone else does...
Due to this hasty (and unplanned) decision, I am not too proud of how I installed it. The great thing about it is I was able to reuse the stock rack-to-cooler hose. I see a lot of you getting fittings to attach the new hose to the old, but I was able route the OE hose around nicely. I did, however, use the Goodyear hose supplied with the kit to go from the cooler up to the pump (which you can see snaked up by the fan shroud; I put the old hose loom on it, too).
ACDelco '99 Z28 upper radiator hose:
#317
Today I finally got around to deleting the factory power steering cooler. As mentioned earlier, I've opted NOT to install an aftermarket cooler, because I've had no issues with boil-over nor system failures with my factory coolerless '98, and therefore felt that for my puposes there was no requirement to install an aftermarket cooler.
I know this is not the popular option, but I thought I would post some specifics for the record. I took some temp readings with the cooler deleted and here are the results:
Car: '02 Z28 with aftermarket 17x9.5" wheels, 275/40 front tires
Temps:
- Outside air temp: 54°F
- Road surface temp (per IR gun): 80-85°F on average
- Power steering fluid temp (in reservoir, per fluid thermometer): 162°F
These readings were taken after 20+ miles of driving in city conditions, including lots of turning and some traffic plus a few curved roads.
In my application, at least at the current moderate outside temps, it does appear that the factory cooler would in fact act as a "warmer", since this car has a stock t-stat and stock fan settings allowing coolant temps to reach as high as ~220-230°F in traffic, vs. the ~160°F temps of the PS fluid.
Again, I'm not necessarily arguing against the aftermarket coolers, I just didn't feel that it was a requirement for my purposes. Moreso, I don't feel that the factory "cooler" is much of a cooler at all in daily-driver applications that use a stock t-stat and stock fan settings. Even with outside temps in the 80°F+ range, I don't believe that my PS fluid will get hotter than the 220-230°F coolant temps that I see driving around the city.
Temps:
#318
Temps:
Temps:
#319
I'd be interested to see what you get in the heat of the summer. These temps are in line with what I got on my cooler during the summer. I've always wondered what effect the ambient temperature plays on this system but didn't want to go through the extra work to test it.
What's the temp of your radiator outlet. The 220°F thermostat temperature should match the radiator inlet temperature. The outlet should be much cooler - and this is where the stock cooler was placed. Unless those outlet temps are above 170°F, I don't think we can say that the stock design adds heat to the system. (It still sucks, though.)
In any event, I'm just glad that I was able to delete that factory cooler before it had a chance to cross-contaminate the PS and coolant and leave me with a big mess.
