Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- Camaro and Firebird: How to Change Power Steering Fluid
Step by step instructions for do-it-yourself repairs
Power Steering Cooling Success
#441
I definitely wouldn't keep the OEM cooler, as it's just a matter of time before it fails and will cross-contaminate the PS fluid and coolant. IMO, the only two options would be aftermarket or nothing at all.
I've never bothered to install and aftermarket cooler myself, and I don't know if anyone here in the north has had trouble with over-cooling in cold weather.
#442
LS1Tech Administrator
Received 1,687 Likes
The other line can obviously just be deleted.
#444
just converted mine
I feel very lucky that I got to this before my stock cooler took a crap !! ...and only b/c of this site did I know I even had one of these. Every other common problem with this car has happened to mine. Anyway, I just installed a Derale remote cooler behind the air dam - pretty easy with all the advice here. I live in Md. and it gets pretty cold but not worried about over cooling as I don't do a whole lot of winter driving. I am going to start auto X ing so I feel I'll need the extra cooling. Thanks to everyone who chimed in here.
#445
How the hell did anyone get the bolt and lock washer tightened? I ended up using zip ties after fighting with it
#446
#447
Any specific tools I need to delete the PS cooler? (line wrench, etc.)
I'm going to attempt this on my 2001 SS. Does anyone have any pictures of the cooler completely deleted with the the line running back into the reservoir? I assume it's pretty straightforward but it doesn't hurt to see a picture.
#448
Pictures would be tough, not a lot of room and weird angles. When you look at it, it'll be pretty clear what to do
#449
It's not mine! woo hoo!
No special tools. Just take the return line that runs from the rack and disconnect it from the cooler; reconnect to the bottom of reservoir -- done!
Well, you'll still need to install the new upper radiator hose (and remove the hose from the cooler to the reservoir), but it's seriously that simple.
#450
I want to do this but havent found a diagram of the hose routing. So i am not sure how the hoses have to be after the PSC delete. I checked my coolant yesterday and its really clean, no brown sludge.
#451
I figured if I wanted to add an external cooler at some point I'd just undo that and extend the lines.
#452
You can then plug off the nipples in the factory PS cooler, or just remove it entirely by using a radiator hose from a non-cooler model (such as a '98/'99 Z28 or Formula).
#454
A frame rail cooler, like the one in the original post, will perform well outside of the direct air flow (due to its fin design) and will move air across itself passively.
#455
I am looking to replace the upper radiator hose now but am wondering if I should drain some coolant first.
Edit: I added three other pics. Two while the original P/S cooler was still in there to give an idea to others of what it looks like. The last one is of it removed. I thought it had an interesting internal design but glad it is no longer part of the car.
Thanks wssix for your info below, I found the radiator petcock and partially drained the radiator to swapped out the upper radiator hose with minimal spillage.
#459
running Derale 13200 based on info from here... The pump to cooler is good no problems no leaks... However the rack to cooler is an issue. It looked like (correct me if im wrong and this would be my issue) that the line from the rack is hard fitted and you need to use a barb to connect more hose to it to get it to where I mounted the new cooler. Now my issue is I got a 3/8 barb and its leaking. not sure why. I know the kit says it includes 11/32 but my boy measured the hose and swears its 3/8. but if anything since the 3/8 barb is larger wuldnt that prevent it from leaking more? not to mention cant find a 11/32 barb anywhere. any info is appreciated thanks ! and figured I would post in here before I created a new thread.
#460
The cooler goes inline on the return line from rack to reservoir... there is no hardline (and no threaded line nuts) involved.
