PLEASE HELP!!! When the key is turned i lose all power!!! My Daily Driver!!
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
So i daily drive a 1999 Camaro with full bolt ons, it runs pretty good with minimal issues. I drove the car home from work yesterday and parked it in the driveway as always.
When i woke up this awful morning (i work at Best Buy and have to wake up for 2am!!) i got in my car and everything was fine, the dome lights turned on. i put the key in the ignition and it did its diiinnggg diiinnggg diiinnggg thing... as soon as i moved the key forward, not even to the next position yet, ALL of the power cut off with a very faint kind of click noise. when i got home today (I'm lucky to be alive) i tried it again with the EXACT same scenario.
i have a professional battery tester and it was 95% healthy...
PLEASE HELP!! WHAT COULD THIS BE??
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
OP, try the simple stuff first, like battery connections. Don't just look at them, but pull them off and inspect them good.
I had an identical problem and it was the battery connectors. Take them off, look for corrosion or pitting and put them back on tight. Grab a meter and ohm the ground from the battery to the block and body and make sure its good. Chances are you have a bad ground like I did (ground on battery was 1/4 loose)
If it was your VATS(Vehicle Anti Theft System) Your dash lights would of came on, and when you turned the key, it would of made that Ding ding ding sound but the car wouldnt of started, and the red Security light would of been on. Sounds like a bad/dirty or loose battery cable to me. The cables have to be on there nice and tight or the current wont flow through properly and your power will just shut off.
