Sponsored by: CARiD
Frozen door locks
Old Dec 14, 2010 | 03:24 PM
robertbartsch's Avatar
Default Frozen door locks
my door locks were frozen today. I took the door key and heated it with a heat gun for 45 seconds and inserted it into the lock and let it "cook" for 1 minute and the door opened.
Question:
Is there anything you can apply to locks to prevent freezing? Does silicone spray work?
Thx...
Old Dec 14, 2010 | 03:37 PM
RedHotG8's Avatar
Silicone spray or WD-40 will stop the locks from freezing.
Old Dec 14, 2010 | 04:14 PM
momartin22's Avatar
if they do freeze instead of using a heat gun, you can put some hand sanitizer on the key hole. Push it in with the key, it melts the ice.
Old Dec 14, 2010 | 06:39 PM
philsblwnz28's Avatar
Last year this happened to me and i live in florida, I had to climb in through the trunk and try to open the locks and barely got them to slide. lol
Old Dec 14, 2010 | 07:21 PM
meine96ws6's Avatar
I would have pissed if I had to do all that..^^^
Old Dec 14, 2010 | 11:38 PM
wssix99's Avatar
Save the manuals!
Ummm... Why not just use the remote?
Old Dec 15, 2010 | 01:59 AM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
Haha!... I was thinking the same thing.
Old Dec 15, 2010 | 05:51 AM
MasterV8's Avatar
I tried that last week, I had to boil the kettle in the end and poor the boiled water over my door which was coated in ice.
Old Dec 15, 2010 | 09:38 AM
my remote battery in the keypad went dead a 10 years ago and I never replaced it. So the remote will "open" a car door that has a frozen lock?
thx....
...my new honda has only one key entry on the driver side and you cannot open the trunk or passenger side doors by any other means....the design blows.
Old Dec 15, 2010 | 02:53 PM
wssix99's Avatar
Save the manuals!
Yea - the electronic mechanism is separate from the key release. I was wondering how your lock froze up. There is a little door on the cylinder that keeps moisture out - but if you are actually using the lock, that door may be wearing out a bit!
Time to get a battery for the remote. Nothing short of a new lock cylinder will keep it from freezing up again. Lubricants will protect the metal parts in the lock, but it won't keep water from getting in and freezing.
Old Dec 15, 2010 | 02:59 PM
93sspcoupe's Avatar
maybe just dont lock the door lol.
Old Dec 15, 2010 | 07:11 PM
pewter2002's Avatar
Spray bottle (or equivalent) with windshield washer fluid, spray in cylinder flushing out the ice, moisture. Follow this with WD40 and this will work for months! Unless you go to a high pressure carwash etc. This works as preventative maintenance as well. Do it once in a while and no more problems - even on VERY worn cylinders.
