Sponsored by: CARiD
HVAC not blowing!
Old Feb 16, 2011 | 08:49 PM
APG12's Avatar
Default HVAC not blowing!
At the beginning of the winter, I pulled out the HVAC controls out of the TA to replace with a camaro panel. I didn't put the new panel in until yesterday, and when I hooked it up, it's getting power but the blower isn't coming on.
Today I put the old panel back in to see if that was the problem, but no go. Any ideas??
Old Feb 16, 2011 | 09:50 PM
The Mighty Texan's Avatar
Your getting power though? Fuse?
Old Feb 16, 2011 | 09:55 PM
APG12's Avatar
The panel lights up, the rear defrost is working. I can hear the air (vacuum?) when I switch from OFF to A/C, vents, etc. But the blower does not come on. Is there a fuse for just the blower? I checked the HVAC fuse and that was good...
Old Feb 16, 2011 | 10:03 PM
Ahh i dunno i havent had to check before, i know that i hooked up the HVAC when i was switching out the lights though and blew a fuse that made it not work.. nothing was working though, thats why i asked how you knew you had power. Not sure on this one
Elthesh's Avatar
A really simple test is this. Remove the kick panel above the passenger footwell, unplug the blower motor and use a meter to check for power at the plug end with the fan on. That will at least narrow down what's going on.
Old Feb 16, 2011 | 10:37 PM
APG12's Avatar
Thanks I'll try this tomorrow.
Old Feb 16, 2011 | 10:38 PM
APG12's Avatar
Yea everything else is working, just not the blower. Thanks though!
Old Feb 16, 2011 | 11:44 PM
SS DNA's Avatar
Hey on my car, when i try to turn on the AC, I have air coming out but not cold and I dont hear the AC kicking in.
I went to the fuse box and took out the relay for the AC and I just jumped it using a wire and the AC kicks in like that.
I never was able to find the problem so Im still stuck....I hope you find a fix
Old Feb 17, 2011 | 05:55 AM
APG12's Avatar
Yours sounds like a problem with the compressor not kicking on. You may have a leak. If there's not enough pressure in the system, the compressor wont kick on.
My problem is with the blower itself not coming on and not blowing any air at all.
Old Feb 17, 2011 | 06:13 PM
APG12's Avatar
So it turns out that I am retarded and just missed this connector!
Now the blower is working just fine, however, I noticed that the air is just coming out of the floor and windshield vents, not the dash vents. I saw some threads about this problem but didn't really read them so time for a search....
Old Feb 17, 2011 | 07:31 PM
Elthesh's Avatar
Well, so long as it isn't something disconnected behind the controls... It's very likely a vacuum check valve. This little piece of crap is located under the hood, passenger side somewhere between the intake and the computer. It should have a few vacuum hoses going into it and will likely be cracked along the "seam" or anywhere else. I've replaced this same piece of junk in my old 99 Z and a 91 TA. Anyway, it's not REALLY a piece of junk. Just annoys me of what I had to go through to figure out what was causing the same problem you're having.
They run about 4 and a half bucks. They won't have a damned clue what you are talking about at the parts store. I just go to the area at Advance that has the vacuum and windshield wiper hose. It was on a rack right near those, a Dorman item. You can get the AC Delco one pretty cheap on Rockauto under Heater and AC controls. If you need part numbers, let me know. Just make sure yours IS cracked first though. Sometimes the crack isn't obvious until you flex the piece a few different ways.
Old Feb 17, 2011 | 08:02 PM
jim ravencraft's Avatar
Hi,
another thing to check!
The resistor which is located on passenger side/pull carpet area/one screw holds it in place. A little tricky but this contols the high speed on blower motor. It usually works at lower speeds/no high speed. Check diverter under dash/ vacuum underhood as stated above. Good luck and have a blessed day............jim
Old Feb 17, 2011 | 08:52 PM
APG12's Avatar
Thanks for the responses guys. I did search and read about the check valve so I will look at that tomorrow. Where can I find the diverter under the dash?
Old Feb 17, 2011 | 09:42 PM
Elthesh's Avatar
The diverter I have no experience with, but I just looked at that 3 way check valve SHOULD be right next to the computer. Mine has one of the vacuum hoses in a "clip" holding it to the car maybe a couple inches away from the computer.
Old Feb 18, 2011 | 06:52 PM
Hi,
the diverter/blend hooks into back of control panel. This controls vents/floors/etc provided working properly. Have a blessed evening........jim
Old Feb 20, 2020 | 03:48 PM
Waters's Avatar
2000 Chevy Camaro v6 my heater wont blow and my hvac fuse on the dash keeps blowing
Old Feb 29, 2020 | 07:20 PM
markano's Avatar
Alright quick info session. AC units (also called Heat Pumps) are not that complicated. Outside there is a big fan which looks like its working from your pic. You said there is cold air meaning the compressor is working, and that there is still freon in the lines. Another component is a capacitor that it necessary to start the compressor and fan, but this must be working as your compressor and fan are working. The fact that again you feel cold air meana thw thermostat is working and no safety sensor is engaged.
