How to vacuum test an LS1
We have thrown every general maintenance at it.
I suggested checking engine vacuum after thinking not only myself but being told by at least 10 different people that "it sounds like a vac problem..."
So we go to hook up a gauge, and have no clue where to do so... Where to start?
Thanks a ton.
Thanks again everyone.
If you've determined that you do indeed have low vacuum and want to test, there are a couple of methods my step-father (a ASE and State-certified Master Mechanic) uses:
1) A spray can of carb cleaner / brake clean / WD-40 sprayed in short bursts around each suspect area individually; if RPM changes then you have a leak in that area.
2) A doctor's stethoscope or single vacuum line from his ear to a suspect component or area - this method helps you 'hear' the leak.
Good luck!
Gary--After doing reading here I finally figured that out, thanks for the tip.
For what it's worth we replaced his MAF with a used unit from an LKQ parts yard(came with 6-month warranty). Cost $40 and didn't do a damn thing. The car bogs under load, bad. Only at low rpm's. The 1st-4th shift of the skip shift used to be smooth as normal according to him(long time ago), but now it bogs the crap out of the car. Similar reaction from any other gear when at low rpm and you step on it; 6th gear is basically impossible and useless, any slight incline and the engine bogs terribly.
Anyways, the used unit didn't help. I have a funny feeling that unit is just as much crap as what he's got under the hood in the first place and have tried to convince him to buy new... But on the flip side, the used one not producing any results makes me think, "what if it was good and that's not the problem, then I'm asking my friend to spend $100-140 on a brand new one for nothing."
If he were to spend that via my advice and his car still run like crap, I'd feel worse than his car runs!
