Throwing a p0306 check it out
Today I also had it ran by a friend at a auto shop with a scanner that scans all cylinders, and #1,5,6 were missing, but out of 20. 1=2 misses 5=1, and 6=14-17,18
I almost thinking it could be a crankshaft positioning sensor. Am I on the right track guys??
When my 02 sensor started going bad I would get the SES blinking at me. Multiple misfires or some **** when I ran the code. Did it off and on and would literally make the car surge and jerk, but it only did this after driving it a while.
Replaced 02 sensor and everything was fine.
I wouldn't think that a injector would be clogged and then when you unplug the battery and plug it back in it runs fine for a while. I would guess a clogged injector would stay clogged. Not intermittent
However, the injector could be going bad. Not necessarily clogged.
Coil pack harness backwards???
Sorry I couldn't help much. I am just trying to throw and idea or two out there. Stimulate your thinking; sometimes it helps people figure stuff out.
Weird thing is that it would do it intermittently. Since the regulator is in the module in the tank, debris goes all the way to the injectors and stays there.
I pulled the injectors all out and hit them with some carb cleaner and they all looked like they were in good shape, descreened my MAF at the same time. Put her all back together and the code is still on but its not surging like before.
Next thing im going to do is switch the coil packs, see if this helps. and do a compression check at the same time... if this fails I will be thinking its the crankshaft positioning sensor or the 02's.
I will swap the 02's to different sides to see if I get any affect... And if this fails... I need you guys! I know my valve springs are not broken, my lifter? brand new pushrods. I just want her to run good again guys!
and one shoots lean, the fuel trims will pull the bank rich to
make up for that (running crappy, and the lean one will still
perhaps misfire).
On the other hand if one's a drooler, the bank will pull leaner
and the other three ought to be showing elevated misfires.
The reset making it run better temporarily means something
like this is going on. You might swap injector 6 for 4 and see
if the problem moves. If it doesn't then you have to look at
single runner vacuum leak or a spark path problem. Misfires
of any sort can fool the O2s into mistrimming, including a
spark (not intake AFR) problem.
