Fix for leaking T-top?
This fixed my leaks.
If its the window glass, then it may not be the T-Top. There are a number of window problems/adjustments that can be the cause. If its in this area, please reply if its the front or back of the glass.
If you look at where the weatherstripping meets the glass from the outside of the car, you can see the "reveal" and follow that along the line of the glass. You'll probably find that the gap between the glass and the lip in molded in to the weatherstripping is larger where you have the leak. (Less common is a situation where the glass is pulled away and out from the weatherstripping - but that's another thing.)
If you have this wider reveal, you can raise the forward glass stop to allow the window to raise up higher in the front. To see the adjustment screw, take off the door panel. The stop itself is inside the door, but you'll see a flange bolt that screws in to a vertical oval from the outside of the panel. (You can also look in the door and see where the stop contacts the plastic ledge attached to the glass.) Just loosen the adjusting bolt, raise it a tad and check the reveal again.
BEWARE - The procedure above is for where you do not have a visible gap in the glass where water comes through. If you have a visible gap, it could be a sign of something much worse, like this: https://ls1tech.com/forums/general-m...-included.html While the door panel is off, its worthwhile to check for the regulator attachments tearing - just in case.
