Vid inside, bad oil leak
What do you guys think?
Rear main or pressure sending unit?
http://www.youtube.com/watch?v=mBGpX...e_gdata_player
looks to be a broken oil pressure sending unit, you may have broken it getting your transmission out. If it was the rear main that bad then the oil would be flying every where off of the flywheel.
looks like it slit its wrists.. holy ****... seems to me if it were the sending unit, it would be coming out with a little more force.... id guess a rear main due to the volume... but the delay makes me believe its the sending unit... you will be able to tell if you take off the flywheel...
