Sponsored by: CARiD
T tops leaking
Old Jan 2, 2012 | 10:06 AM
dkcoleman01's Avatar
Question T tops leaking
I've notice my tops leaking when it rains . Do anyone know where to get new weather stripping or how I go by fixing my leak?
Old Jan 2, 2012 | 12:17 PM
777Shock777's Avatar
Mine do this too so I'm subbing haha.
Old Jan 2, 2012 | 05:26 PM
jaxcam02's Avatar
a cheap thing you could try is to lay a layer of silicon around the outside edges of your weather striping and if that doesnt help try puttin a small layer of silicon on the contact points of the striping, hey its worth a try before replacing it. I've seen replacements on rockauto.com a while back
Old Jan 2, 2012 | 05:36 PM
02ws.sik's Avatar
youngs fbody has it. find out what side first. get a hose have some one sit inside and find where it is at. then go there they have watcha need.
Old Jan 3, 2012 | 07:30 AM
wssix99's Avatar
Save the manuals!
Where is the leak getting through? You probably don't need new weatherstripping unless the stuff you have is rotted. It may be a case of adjustment or mechanical repair.
Old Jan 3, 2012 | 07:56 AM
Thanks guys for your input..... @ wssix99 it's leaking where the driver side and passenger window meets the the t - tops
Old Jan 3, 2012 | 10:07 AM
02ws.sik's Avatar
So thats the weather stripping that is on the ttop when you take it off?
Old Jan 3, 2012 | 10:27 AM
wssix99's Avatar
Save the manuals!
Yep. That's not a weatherstripping problem - as long as your weatherstripping isn't mangled, cracked, or pitted.
Do you see any gaps between the window and weatherstripping where the water is getting through? Is it only towards the front or back of the car? If you look at the way the T-Tops match the level fo the roof, is it different on one side of the car or another?
Old Feb 11, 2012 | 01:14 PM
SupermanZ28's Avatar
I need help too... My passenger side leaks going down the back part of the t-top. It's the edge where the ttop meets the weather stripping... I've tried putting a layer of silicone in that corner to make it a tighter fit with the ttop, but it still leaks...
