Sponsored by: CARiD
Brake squeal while driving
Old Jun 14, 2012 | 05:42 PM
Y87bird00's Avatar
Default Brake squeal while driving
I recently replaced the brakes on my 2000 firebird. They have been on for a while with no problems. I did the bedding and greased them up as told. But now as I drive the left rear squeaks loudly while driving. It stops when I apply the brakes, only occurs when driving... Any ideas on how to stop it?? Thanks!
Old Jun 14, 2012 | 05:48 PM
Breathing Fire's Avatar
Its your break hardware kit. You know those little silver colored tabs that go between the pad and bracket? Its rubbing the rotor. Had the same issue a while back. It won't hurt anything but will probably drive you insane.
A GM hardware kit will stop it if you want to spend the money.
Old Jun 14, 2012 | 06:18 PM
Y87bird00's Avatar
It's already driving me crazy... Thanks for the help. How much do the gm kits run?
Old Jun 14, 2012 | 07:33 PM
Y87bird00's Avatar
It's also only there when I turn any to the left..
And to elaborate on the squeal it is on and off like it's only a certain spot that it hits. When I speed up, it speeds up, when I slow down it slows down
Old Jun 14, 2012 | 10:53 PM
need4fun2469's Avatar
I had the same problem. I took a pair of snips and cut 1/8" off each end. No more squell
Old Jun 15, 2012 | 03:18 PM
Y87bird00's Avatar
What did you snip?
Old Jun 16, 2012 | 04:35 AM
the ends on each side. This is the part that is scrapping against the rotors. If you don't have snips, you can use a grinder to remove the material.
Old Jun 20, 2012 | 11:20 PM
Y87bird00's Avatar
I was finally home long enough to try and snip the hardware but ended up screwing up everything. When we did the brakes I used locktite on the caliper bolts.. I loosened them but the rubber part spun along with the bolt, last time I could hold this with my fingers but it was stuck this time. I tried retightening the bolt and it SNAPPED in half... Most still stuck in the caliper. The caliper still stays on so hopefully I can make it somewhere to get the bolt tapped out.. So mad at myself!
Old Jun 22, 2012 | 12:23 PM
i hope you are able to get the rest of it out.
