Can someone point to me where the secondary air pump is
LS1Tech Sponsor
Received 1,189 Likes
The secondary air system has a few parts. The vacuum solenoid and diverter valve (has a large hose coming from the side and a small vacuum line on the top) are going to be on the driver side of the engine bay just above the rear coils. The air pump itself is located behind the splash panel in front of the driver front tire. Once you remove the splash panel you will see the secondary air pump on your F Body that has a large rubber hose coming off of it. You will need to check on a cold start up if the pump is powering and if its not check the fuse under the hood. If your pump does power-on, you will then check for air movement at the outlet of the hose that goes up to the engine from the pump.
