Sponsored by: CARiD
windshield washer motor or button?
Old Sep 3, 2014 | 02:50 PM
unreal1171's Avatar
Default windshield washer motor or button?
i press the button on the steering wheel, 2001 fbird, and it does nothing, the windshield wipers work just no fluid coming out, can't hear even if it is trying or the button just doesnt work, any way to check which i need to fix?
Old Sep 3, 2014 | 07:06 PM
Daniel Richards's Avatar
just buy the washer pump it's like 16 bucks at Advance Auto and takes a few minutes to swap out (unless you have large hands), its the cheaper of the 2 parts and the easier of the 2 parts, you could pull it and test it by putting power straight to it from the battery for just a second to confirm.
Old Sep 3, 2014 | 07:29 PM
unreal1171's Avatar
thx will do!
Old Sep 4, 2014 | 07:00 AM
wssix99's Avatar
Save the manuals!
You might also have a clogged line. Have someone listen to the pump with the hood up to confirm. If its a clogged line you can reverse flush it.
Old Sep 4, 2014 | 04:15 PM
unreal1171's Avatar
i looked today and can't seem to see where the pump is or reverse flush it, anyone do a writeup on this? shbox didnt seem to have it
Old Sep 4, 2014 | 11:16 PM
wssix99's Avatar
Save the manuals!
Look for the wires going in to your washer fluid tank. That's the pump.
Old Sep 5, 2014 | 01:09 PM
unreal1171's Avatar
thx, ill look today
Old Sep 14, 2014 | 04:34 PM
unreal1171's Avatar
holy crap i cant follow it anywhere it goes almost under the car it seems
Old Oct 5, 2014 | 03:57 PM
unreal1171's Avatar
found it right at the front where the hood comes up, switched it out and nothing, that sucks cause that part on the steering column is not only expensive but a pain to switch out.
Old Oct 5, 2014 | 04:01 PM
unreal1171's Avatar
anyone have a how to on changing that? maybe going to a junkyard to find the part
edit* when i disconnected it i blew through the hose to see if it was stuck and it pushed through, so at least some hole is open on the other end.
Old Oct 5, 2014 | 05:49 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
Since you have access to the pump and its' wiring,you could wire in an aftermarket push-to-energize/spring return off switch somewhere to manually control the pump.
Old Oct 5, 2014 | 06:28 PM
unreal1171's Avatar
oh you mean like run a wire that goes to the pump directly and splice in and hook it to a manual button somewhere inside?
Old Oct 5, 2014 | 07:48 PM
yes,easier than working on the steering wheel repair.
Old Oct 6, 2014 | 11:17 AM
wssix99's Avatar
Save the manuals!
The wires for this are in a connector at the base of the steering column, where the wires running down the column plug in to the car. This might be a good place to test the circuit. (you could apply 12V at the right wares in the connector) If the wires work from that point and you confirm the switch is bad in the column, you could tap in easily at that connector.
Old Oct 6, 2014 | 01:43 PM
unreal1171's Avatar
nm, thx for the help, apparently i got the switch to work and the pump now works, Awesome, glad it was just the pump. no need for extra work, yeah! lol
