Sponsored by: CARiD
Keyless entry question.
Old May 24, 2004 | 01:31 PM
JensTA1's Avatar
Default Keyless entry question.
I have a 98 Trans Am that started doing some screwy stuff yesterday when I lock or unlock the car. When I press the unlock button on the keyless remote the headlights will pop up and then go back down. Once they're down the motor on the left headlight continues to run for about another 3 or 4 seconds. The same thing happens when you lock the car. It also happens if you use the key to unlock the car and then turn the ignition to ACC or you lock the doors with the button on the door and then shut the door.
I looked in the manual and there is a bunch of stuff on how to program door locks and alarms but I didn't see anything on the headlights flipping up automatically. I'm hoping someone here may have seen this before and know how to fix it without going to the dealership. Thanks.
Old May 24, 2004 | 02:47 PM
Angus's Avatar
What the heck is that thing doing? I have never heard of that happening!
Old May 24, 2004 | 03:46 PM
99-LS1-SS's Avatar
STF Veteran
Is it the factory remote? If so you have some serious wiring issues.
Old May 24, 2004 | 03:50 PM
ActionJack's Avatar
I almost had my car 'jacked' and this happened. I took it to the dealership (still under warranty) they said all they did was replace the light motor.
Good luck with it.
Old May 24, 2004 | 07:06 PM
slow's Avatar
your headlight motor is stripped.
Replace the motor, or do the 180 mod, and your problems will be solved
its due to the crappy design, and current sensing of the headlight control module.
Ryan.
Old May 24, 2004 | 08:14 PM
Danny2tek's Avatar
Ryan.
Old May 25, 2004 | 07:41 AM
JensTA1's Avatar
Thanks for the help so far. I had one of the motors replaced a couple years ago. This time I'm going to try the brass gears. That should fix the problem with the motor continuing to run. However I am still scrathing my head as to why they automatically flip up and down when you lock or unlock the car.
Old May 25, 2004 | 10:17 AM
TA TED's Avatar
STF Veteran
Ryan nailed it on the head. When the keyless pulses the park light circuit, the signal is sensed by the headlight control module and if the motor is stripped it'll scare the **** out of you. Happened twice on my old 97 LT1.
Old May 26, 2004 | 06:55 AM
JensTA1's Avatar
Thanks for all your help. I did the 180 mod and that fixed it. I have the brass motor gears on order. What was GM thinking with that design. It seems like something Ford would do.
Old May 27, 2004 | 10:42 PM
JohnR's Avatar
Please email me where you bought the brass motor gears. I have a '99 and mine will probably need to be replaced soon.
JohnR@FlowstarInc.com
Thanks,
John
Old Jun 16, 2004 | 10:45 PM
25thBird's Avatar
try e-bay... that's where I got my brass gears
