Hamster in my engine
Okay seriously. I had to replace every pulley, both belts with Gatorback belts, water pump, alternator, and power steering pump before I got rid of my squeals.
12563326 - Main idler
12560344 - Main tensioner (w/pulley)
12557335 - A/C idler
12560345 - A/C tensioner (w/pulley)
That was for my '02 car. For a 2000, if yours was an early build then it might use a different main idler pulley. There was a mid-year change to the alternator bracket that necessitated a different pulley. I don't have the VIN breakdown handy, but if it was a late 2000 build then you should be fine with the number posted above. If it was a early build, then you might need the '98-'99 style main idler.
Goodyear makes a really nice Main and Tensioner pulley for the car. (I think these are now sold and marketed under the brand "Continental Elite")
Dayco also does a pulley for the A/C idlers. I've had them on for years and they have been great: https://ls1tech.com/forums/general-m...ley-belts.html
What year is your car?
They're different in the earlier years, primarily 99 than 00 - 02.
I think the later year pulleys have a different offset and will not fit properly.
For what its worth, my Delco's made it to about 180 but then squeeled horribly. Went with Goodyears, never looked back.
It is not correct to list the division as '99 vs. '00-'02. That's confusing and fails to recognize that 2000 is the specific model year where the change took place.
Just to set the record completely straight, the VIN breakpoint was Y2107225 (the bulletin, TSB #00-06-01-008, was issued on March 22, 2000.) That is for model year 2000; cars built prior to that VIN have the old style pulley, cars built after have the new pulley.
If one wants to convert to the new pulley, the part number for the updated bracket is 12563327.
