front passanger turn signal
Try replacing the front bulb first..if that doesn't work, check the socket and replace if necessary, finally if that doesnt work, check the DRL module behind the radio.
Save the manuals!
What does this mean? If your hazards work but turn signals do not, then that's a flasher problem, but if there is another mode where the lamp doesn't work, then you may have other problems.
Are you talking about "on" when you turn the headlights on? Do your DRL's work?
If the turn signal flasher was bad then both turn signals would stop working not just one as the flasher itself does not control both sides (driver and passenger) separately, going through the flasher itself they're all apart of the same circuit making it impossible for the flasher to single the two sides out. If HAZARDS work on all four sides - and the turn signals do not.. POSSIBLY the DRL module, check connections on the DRL module, wiggle them while the turn signal is on, see if it comes up
Save the manuals!
BTW - We've had a number of posts on this issue in the Electronics section. As people change bulbs, etc. over the years, that resistance bogey moves around. Sometimes the left side hangs up on people and sometimes its the right.
Usually, a bad DRL module will express the same problem for the hazards and turn signals as both go through a common relay in the DRL module.
Try inspecting the bulb to see if the two metal wires are broken, if not, maybe your light bulb is not making sufficient contact with the socket, which has happened to me. Usually just touching the bulb gets it to light back up, which is a problem when your hitting bumps in the road and it stops working!
However, what your describing may possibly be the turn signal switch in the steering column. When it went bad, my factory switch, I do remember my turn signals not functioning while the hazards did. So, maybe you are describing a bad turn signal switch.
