Sponsored by: CARiD
Is there a write up on remove/replace for the steering rack and pinion assembly?
Old Jun 13, 2017 | 02:23 PM
FCar2000TA's Avatar
Veteran: Air Force
Default Is there a write up on remove/replace for the steering rack and pinion assembly?
I tried a search, but didn't see anything.
I have a replacement rack and pinion en route, and wanted to read up on the remove/replace procedure before I start working on it.
Old Jun 13, 2017 | 07:30 PM
TA_Freak's Avatar
There is a sticky somewhere. I wrote something up when I did mine. See post #7.
https://ls1tech.com/forums/suspensio...-write-up.html
Old Jun 14, 2017 | 12:07 PM
1 FMF's Avatar
for the driver's side bolt holding the rack the easiest way is undo the nut enough to fit a sawzall blade in there and cut the bolt. Otherwise you have to raise the engine so you can pull that bolt up and out without the oil pan being in the way. What you can do now is remove the passenger side bolt and take that to match up a replacement. sorry i forget what size it is. Then when reinstalling just put the bolts in from the bottom, and the nuts on the top.
before removing the steering shaft from the rack, take a piece of rope and tie off your steering wheel so it cannot rotate, so without a doubt you know where center is, so when reinstalling the steering shaft the steering wheel will be centered and the rack will be centered = no problems. if you over rotate your steering wheel then you'll break wires in there, and with the steering shaft disconnected the steering wheel can rotate very easily.
Old Jun 15, 2017 | 10:18 AM
FCar2000TA's Avatar
Veteran: Air Force
I really don't like the idea of sawing a bolt off. Plus, my sawsall died a few months ago. Guess I'm taking the car to the mechanic to replace the steering rack. Bonus is it comes with a power steering flush. I guess $275 isn't bad for me not having to spend a weekend under the car.
Old Jun 15, 2017 | 10:41 AM
TA_Freak's Avatar
While they're at it, if you have not changed out those factory motor mounts, I'd get those done since your mechanic is going to have that engine jacked up..... unless they're going to saw that bolt.
Old Jun 16, 2017 | 10:35 AM
FCar2000TA's Avatar
Veteran: Air Force
Already have ploy mounts. I thought about going to solid, but the polys are good for now. I might go solid when I get a built motor down the road.
Old Jun 16, 2017 | 11:26 AM
TA_Freak's Avatar
Good deal!I swapped my oil pump a few years ago which lead to a double roller timing chain and motor mounts since I had the engine jacked up/k-member dropped to drop the oil pan. One of those "while I'm there ....." scenarios.
Old Jun 16, 2017 | 11:53 AM
FCar2000TA's Avatar
Veteran: Air Force
That is the same way that I think. That's why I got a 102mm throttle body when my 90mm one died.
Same reason I am going to get a bigger fuel pump when my friend does the mini-tub and roll cage... the fuel tank is coming out, so might as well upgrade the fuel pump while we're there.
Old Jun 16, 2017 | 12:06 PM
TA_Freak's Avatar
Ha ha ... my thinking exactly. I always look at a needed repair as an opportunity .... aka .. upgrade!!
