Steering wheel swap
Excuse my lack of knowledge. I have two questions.
1. The air bag. Can I successfully splice the airbag wires together. The old style plugs directly into the back of the steering wheel and the newer one has a pigtail with a lock on it. Can I cut a pigtail from another car and splice it successfully without causing an airbag mishap?
2. The horn spring wire. I have no idea where that came from or where that goes. Can someone give some insight? It just pulled out with a spring around it. I may have broken it.
BTW - Odd that you have this problem. I have a 1999 and the plug I have is like you describe for your new wheel.
3) What about the clock spring? Don't you need a new one to handle the wires for the controls???
You likely (98% sure) broke the socket it goes into. This is a part of the turn signal cam. This is a $8 part that you can get from any auto parts store, but you have to take the column lock plate apart to get to it. (See instructions in the stickies.)
The 1998 and 99 camaro use different plugs than the 00+
The best solution is to buy an airbag from a Monte Carlo, it will bolt and plug right in.
There is no adapter available I'm aware of, but there are detailed instructions on how to add the steering wheel controls on a 98-99 car.
I'm running a base model 2002 camaro wheel without radio controls. I had the air bag light tuned out
i am now researching on how to replace/install the born spring. I need the horn..lol
Nonono, you need the air bag for a 98-99 Chevy venture or Monte Carlo. The 2000+ camaro air bag is an inset male connector, and the 98 wheel needs the female connector (I might have that backwards)
My stock horn connectors still worked when I did the wheel swap, I believe my wheel came with them on it and it plugged right in to my factory horn cable
