Let's talk about DexCool...
ive also been aware of many law suites with GM over dex-cool not living up to its claim.
if you have ever heard dex-cool refered to as 'dex-clog' it is actually possible for it to gel up if not changed prior to its 100k mile rating and cause damage to the cooling system.
my .02 fwiw
what he said. green bad...orange good. plus, changing it sooner can't hurt!
i personally am still running dexcool, but when its time to switch im going to use honda radiator fluid. ya ya ya blah blah damn ricers whatever, the truth is dexcool sucks, and honda rad fluid is an excellent replacement, it is silicate free so it doesnt erode alumnium (duh, practically all honda engines are aluminum) and in my experience it has help up very well. smells good too, and its blue. later!
Jeremy
I see this every day at work with people who refuse to change any of these fluids and then wonder why their cooling system is filled with sludge, their trans took a dump, and their rear ends are shot. Preventive maint is ALWAYS cheaper than fixing a problem caused by neglect. Just my .02
What everybody else says about DEXCOOL.
DEXCOOL is at least as good as the green stuff for modern engines. It was designed to better transfer heat, reduce silicate gel & scale, and increase water pump life. The big problem with it is that it is so easily contaminated. Simply putting tap water in it to top it off will reduce its service life. I've heard that simply letting coolant level fall and getting outside air into everything will contaminate it.
But it's easy to beat once you know those things. Keep it topped off with distilled water, change it at approx 3 year intervals, and you should be as good as with the green stuff.
My wifes blazer is a mess inside the colling system from this crap. Once it gets exposed to air it goes all to hell real quick.
Case in point: A 97 Astro at work. Pulled the radiator cap off and it looked like a couple inches of red sludge at the top. Cleaned that out and everything else looked brand new inside. Cause of the problem? No coolant in the overflow and had been low for some time. Even though the problem looked bad and the Dexcool "looked" like it was corroding like hell.....it wasn't by any means.
