Sponsored by: CARiD
coolant light won't turn off
Old Jul 15, 2005 | 02:00 PM
boyd's Avatar
Restricted User
Default coolant light won't turn off
Got this minor problem with my 95 transam,the coolant light won´t switch off .Checked the coolant level and for leakings .They told me... ones it goes on you have to eleminate it from the computer memory....what u guys think?thx,Boyd
Old Jul 15, 2005 | 02:14 PM
Muffracing's Avatar
Try unpluging the sender. The light will useally go out if you have a bad coolant level sender.
Old Jul 15, 2005 | 02:53 PM
boyd's Avatar
Restricted User
thanks but did not help either!
Old Jul 16, 2005 | 02:14 PM
'Trust''s Avatar
Are you sure you unplugged the right sensor? that sensor went bad on both my car and my friends 97 ws6, unplugged it and it went away, its on the driverside of the radiator facing the motor, i had to use a flat head to pry his off because his engine bay is real tight.
Old Jul 18, 2005 | 12:10 AM
Danny2tek's Avatar
If you unplug the sensor while the motor is running the light will stay on. First unplug the sensor then turn on the engine the light should remain off. If its off, then proceed to purchase part#10096163. Can you tell I replaced mine yesterday ? Cost me $55 from a dealer.
P.S...Its on the passenger side of the radiator if your looking at the motor. Not the drivers side.
Old Jul 18, 2005 | 12:49 AM
BOBA_VETT's Avatar
From my experience (of having to change several on an LT1), that's your first indication that your water pump is gone/going.
Old Jul 18, 2005 | 11:43 AM
shouldaboughttheZ's Avatar
gmpartsdirect has it for $25. But you probably would have to wait 2 weeks, as I did on some AIR gaskets.
Old Jul 20, 2005 | 02:22 PM
boyd's Avatar
Restricted User
thanks for all ur help guys!!!!!!
Old Jul 20, 2005 | 06:09 PM
Danny2tek's Avatar
It was the sensor?
