Sponsored by: CARiD
door hinge replacement
Old Jul 28, 2005 | 10:23 PM
01350ss's Avatar
Default door hinge replacement
2001 camaro, how do i replace the driver door hinges?
Old Jul 28, 2005 | 10:41 PM
01WS6/tamu's Avatar
I am not sure but I think you have to drill out the spot welds on the body and bolt the gm replacement in. If it is sagging I believe you can replace the pins and bushings in it unless it has wore the hole oblong. If it has the new bushing would not last long.
Old Jul 30, 2005 | 04:44 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
If it were me, I would replace the hinges as a unit. Trying to balance a heavy door and line all that stuff up is rough enough with help, by yourself it's a massive cluster f@#K. My drivers' side is getting sloppy and I will just replace the whole hinge units.
Old Aug 10, 2005 | 08:45 AM
mpmWS6's Avatar
Any chance that someone knows the part number for the driver side door hinges? I need the lower hinge.
Thanks!
Old Aug 11, 2005 | 02:14 AM
ACW's Avatar
ACW
93-02 F-Body Front Side Door Lower Hinge, RH = 16628998
93-02 F-Body Front Side Door Lower Hinge, LH = 16631043
93-02 F-Body Front Side Door Upper Hinge, RH = 16630874
95-02 F-Body Front Side Door Upper Hinge, LH = 16630875
93-94 F-Body Front Side Door Upper Hinge, LH = 16626519
Old Aug 11, 2005 | 07:43 AM
mpmWS6's Avatar
Thanks for the info ACW!
Is RH mean the passanger door and LH mean Driver door?
Old Aug 11, 2005 | 08:35 AM
Valkyn's Avatar
My drivers door makes a creeky groaning sound when i open/shut it. Ive tried oiling the hinges but didnt help.
Are the hinges probebly shot? I looked at them and they looked ok at a glance.
Old Aug 11, 2005 | 06:58 PM
ACW's Avatar
ACW
Yep
LH (Left-hand side) = driver side
RH (Right-hand side) = passenger side
Old Aug 11, 2005 | 08:09 PM
mpmWS6's Avatar
Thanks a bunch!!!
