Sponsored by: CARiD
Does anyone have a problem with driver mirror shaking?
Old Aug 31, 2005 | 02:02 PM
Mr. Trick's Avatar
Default Does anyone have a problem with driver mirror shaking?
My driver side alway shakes and wobbles as I go down the road. Is it just my car or dous any one else have this problem? What can I do to fix it?
Old Aug 31, 2005 | 02:28 PM
Mr Incredible's Avatar
Mine does that too.
I thought I'd fix it when it came off in my hand one day. I put one dab of epoxy and four dabs of silicone sealer just like what it came with.
Still does the wobble thing.
Old Aug 31, 2005 | 08:44 PM
Pewterpower's Avatar
Hell, yes....
These doors are so frickin big, and they close with such a clunk, I'm suprised anything at all stays attached to them.
Old Aug 31, 2005 | 10:29 PM
The PAT WS6's Avatar
YUP! mine does it to and its driving me nuts let me knw if anyone finds out how to fix em
Old Aug 31, 2005 | 10:58 PM
Mexican's Avatar
yea when my system is hittin lol but yea I think just about all f-bodys do it
Old Sep 1, 2005 | 09:42 AM
Mr. Trick's Avatar
I want to take my mirrors off to paint them body color. Does any one know how to get the mirrors off the car? Anyway while their off I'll check to see if I can fix it. And if it works I'll let you guys know what I did.
Old Sep 1, 2005 | 11:24 AM
LoudmouthLT1's Avatar
Both of my f-bodys have had the driver mirror shake, it's odd that the passanger one doesn't do it though.
Old Sep 1, 2005 | 11:27 AM
1FSTBRD's Avatar
hey mine too let us know when you figure it out mine is a 98
Old Sep 1, 2005 | 08:57 PM
Cuz the Driver's door gets alot more slammin than the passenger. Same goes for window motors. Its almost always the drivers that goes first.
Old Sep 2, 2005 | 04:13 PM
ACW's Avatar
ACW
Here's how to remove/reinstall the mirrors
Mirror Replacement
Removal Procedure
1. Remove mirror bezel bolt/screw.
2. Remove rearview mirror bezel.
3. Remove remote handle from bezel, if equipped.
4. Remove door trim panel from door.
5. Disconnect electrical connector (if equipped). Pull rosebud clip on electrical connector from mirror. Pull apart connection.
6. Remove outside rearview mirror nuts from mirror assembly.
7. Remove outside rearview mirror.
Installation Procedure
1. Install outside rearview mirror.
2. Install outside rearview mirror nuts to mirror assembly. Tighten the outside rearview mirror nuts (1) to 12 N·m (106 lb in).
3. Connect electrical connector (if equipped). Push connectors together. Push rosebud clip into electrical connector.
4. Install door trim panel from door.
5. Install remote handle from bezel, if equipped.
6. Install rearview mirror bezel. Important: Ensure that retainer guides on back of bezel is aligned with holes in applique.
7. Install rearview mirror bezel bolt/screw. Tighten the bolt/screw to 2 N·m (18 lb in).
