newbie oil change
Can I run the car up on some ramps or should I jack it up
Also should I change it warm or cold
How much will it take (using mobile 1 5w-30 synthetic)
Should I put a certain amount in, run the car for a few minutes, then put the rest in?
Thanks for any tips, I'm sure it's a simple question, just not wanting to mess anything up
A pair of ramps is enough.
Warm is best
I do 6 quarts and use the longer filter (k&n 2006)
I primed the filter with half a quart then installed the filter. Next I put in the rest of the 5.5 quarts.
Change it when the oil is warm
6 quarts will be enough get the longer filter (delco gold, wix mobile 1, or K&N are good filters stay away from Fram oil filters)
Prime the filter with 1/2 quart, wipe a little oil on the seal, and spin it on, add the rest to the engine, start car check for leaks
Get the 5 quart jug @ walmart, and one one quart (to pour into the filter)
I use the long K&N filter and 6 qts.
I fill my filter up with oil before I install it. I let it soak in and keep filling it until it won't accept any more. Install the filter and put all the rest in the car.
That's about it. Just another oil change.
98's dont have an oil life monitor.So nothing to reset.
i've got all the war from my church (nother town) all the way to the house and back just to change the oil real fast lol....what a waste of gas
