View Poll Results: change out your own spark plugs or take them somwher to get changed?
Change them out your self
86.04%
Take them to a mechanic
13.96%
Voters: 831. You may not vote on this poll
Change your own spark plugs or take it to get serviced??
Old 02-24-2007, 10:34 AM
  #221
Orange Juice's Avatar
Short 3/8 rachet, 3/4socket to go over the end of your sparkplug socket and the best tool of all a 2-3" peace of 3/8 hose that you push over the end of the new plug. Makes it alot easier to install the new plug
Old 02-24-2007, 12:40 PM
  #222
MonkeyBoneSS's Avatar
Just changed mine this morning! Took me a little over 2 hours. Yea number 8 was a BITCH, had to tackle that one from underneath as well. I read the write up from I believe install university and it helped out a lot!!! Not to mention having all the right tools helps out a lot too.
Old 02-24-2007, 02:00 PM
  #223
99corvette's Avatar
Did you take all the coil packs of the passenger side?
Old 02-26-2007, 02:30 PM
  #224
99corvette's Avatar
ok guys i need help, i am trying to change my plugs today because my car is missing, and i got stuck. I couldnt get the last bolt off of the passenger side coil pack. The one in the very back that is underneath the wiper cowl. There is a big black hose that runs into the firewall that is it my way. Whats in the hose? Can i undo it and move it out of the way? Thanks
Old 02-26-2007, 03:45 PM
  #225
BaddillaK's Avatar
probably your heater hose, and if it is you may end up losing/spilling some coolant, but other than that you really dont have to worry about messing it up by removing a heater hose. I AM NOT possitive that it is your heater hose with out seeing a pic of it so you need to be sure of it. It could also be an ac line which would have an aluminum style fitting and not just a clamp.
Old 02-26-2007, 06:26 PM
  #226
99corvette's Avatar
here it is......its the rubber hose that is in front of the rachet, right next to the metal one.
http://www.installuniversity.com/ins...sity/index.htm
Old 02-27-2007, 02:43 PM
  #227
flash12t's Avatar
just get either a deep socket and try it that way or wrenches both ways were a pain in the *** but if i can do it anyone can do it gear wrenches work the best!!
Old 02-27-2007, 05:48 PM
  #228
99corvette's Avatar
Well i couldnt get that last bolt off of the coil pack rail, so i just said screw it, and i got number 8 from underneath the car. But what really pisses me off is that none of them were fouled!
Old 02-28-2007, 05:47 PM
  #229
SIC LSX's Avatar
I used the new swivel header ratchet wrenches from craftsman! took me about 5min to take back bolts out and i have big arms! That's why you don't put the back few bolts in
Old 02-28-2007, 06:10 PM
  #230
99corvette's Avatar
Well some how i found it easier to so from underneath, but if you have big arms, dont even try. I have skinny arms and mine barely fit.
Old 03-01-2007, 03:45 PM
  #231
SIC LSX's Avatar
I got mine it with a few cuts on my arm Now that i didnt put the back 3 bolts back in i can do a full swap in 15 min take out 3 coil pack bolts on each side and they are off nice and easy
Old 03-01-2007, 05:57 PM
  #232
99corvette's Avatar
I couldnt ever get that last bolt off. There was a damn heater hose in the way. If the 10mm didnt have to be a deepwell, i could have got it.
Old 03-01-2007, 08:56 PM
  #233
joecar's Avatar
#8 is even easier with LT's installed and AIR deleted.
Old 03-01-2007, 09:11 PM
  #234
MCBRIZ28's Avatar
Just replaced mine today took every bit of 20 minutes
Old 03-01-2007, 09:25 PM
  #235
99corvette's Avatar
Yeah my AIR and EGR have been deleted, which helped a lot. But i have the stock manifolds
Old 03-19-2007, 11:38 PM
  #236
johnnymg's Avatar
Originally Posted by 2002CobraKiller
Do most of you all change out your own spark plugs or take it somewhere to get chaned ive been calling around and everyones telling me the same thing around 185 to 215 $ just for labor. For those of you that do change them out your selves whats the best way to do it, i know those back to on the passenger side are really tight in there, any help would be appreciated.
My local Chevy dealer quoted me $650 for new plugs and wires today.
Saying I'm stunned would be an understatement!
JohnG
Old 03-20-2007, 12:14 AM
  #237
Optimus_Prime's Avatar
It will really **** you off if you do it yourself the first time...Took me about 4 hours my first time...2nd time around about half an hour.
Old 03-20-2007, 06:17 PM
  #238
99corvette's Avatar
JohnG
That doesnt sound right, i went and got a quote for my corvette, which i know is easier, but the same motor, and they wanted something like $250. But its not really that bad, I had help in my corvette and it took me 2 hours to change one side, and my buddy the same to do the other side. Then about a wek ago i changed them on my camaro by my self, and took i total of about 3 hours. I just worked on it a hour at a time for 3 days to keep me from getting discouraged.
Old 03-20-2007, 06:44 PM
  #239
prietodogg's Avatar
I change mine with no problem at all but then again i got LT headers I can change all 8 in less than an hour Headers give you a lot of room!!!!!!!
Old 03-20-2007, 07:07 PM
  #240
99corvette's Avatar
I cant wait to get headers! My hands are cant go through that again! LOL
Quick Reply: Change your own spark plugs or take it to get serviced??
