Sponsored by: CARiD
seat noise
Old Sep 15, 2005 | 09:41 PM
stangkiller's Avatar
Default seat noise
passenger seat sounds like a bird chirping when i hit bumps, any ideas.........
Old Sep 15, 2005 | 11:43 PM
ACW's Avatar
ACW
Here's a possibility:
Seatback hinge recliner bolts not tightened to specifications.
From a GTO thread, but a few more ideas for things to check: https://ls1tech.com/forums/pontiac-gto-2004-2006/241966-passenger-seat-rattle.html
- "I had that happen. I raised the headrest and it stopped."
- "I think I narrowed it down to the side bolster hitting the arm rest. I reached over a pushed on the arm rest and it stopped."
- "Plus I reclined the passanger seat a bit. Seems to help."
- "The window felt! If I crack the passenger window the rattle / squeak stops.
I was told that this is common. Reason wax residue in felt wil cause noise. Take alcohol to the felt and wala the noise is gone."
Old Sep 15, 2005 | 11:48 PM
multiplicityZ's Avatar
my car does the same thing, i have found that it is the part of the seat belt that buckles into the female part, it is that plastic lining piece, that is rubbing up against the leather....annoying.
you can fix it for a while. then it will works its way back into place and start squeaking again.
Old Sep 16, 2005 | 03:44 PM
sounds unfixable, i might as well just have a passenger with me everywhere i go, maybe a blow up doll that way i can use the hov anytime i want
Old Sep 19, 2005 | 08:22 AM
01formula6's Avatar
My car does the exact same thing. It is definitely the seatbelt rubbing on the leather. I think I might just keep the passenger side buckled at all times.
Old Sep 20, 2005 | 01:35 PM
AronZ28's Avatar
That's what I do
Old Sep 21, 2005 | 01:14 AM
boondiggys's Avatar
a bird huh maybe theyve created a nest below it and are secretly planning your demise...
Old Sep 23, 2005 | 02:14 PM
i wouldn't doubt it, birds hate my car. its black and one day i had so much **** on it, it looked like a dalmation.
Old Sep 23, 2005 | 05:17 PM
Speed Density's Avatar
hashtagBMW
ahhhh, lol, my pass. side makes noises too, its anoying, but sometimes you got to deal with it.
