M6 maintenance
Fluid Change:
1) Locate the drain plug which is towards the back of the tranny. You will need a 3/8 extension to unplug this.
2)Let the fluid drain. Should take about 10-15 min.
3) Tighten up drain plug.
4)Locate fill plug on side of tranny(Drivers side). Use the same 3/8 extension to loosen and start pumping the fluid in using the cyphon.
5) The tranny will be full when the fluid starts to come out.
6)Tighten up plug and you are good to go!
HTH. Any other questions lmk
Fluid Change:
i would take the fill plug off first, because what happen if you drain all the fluid and can't get fill plug off!!!
Some directions would be great.
