Anyone had problems with NGK Iridium plugs?
So, here's my situation; I changed the plugs and wires on my car to some NGK TR-IX Iridium's gapped at .035 (that are 1 heat range colder) and some Magnecor wires. The car ran great for about a week and then it developed and interesting miss last Friday. It's a constant miss, on 1 or 2 cylinders it seems, and it doesn't happen when you first start the car when the engine is cold and/or it's been sitting for a while. It's definitely associated with load too. In 1st and 2nd you can get it to go away if you hold part throttle at higher RPM, but once you get on the gas it starts missing. In 3rd and higher gears it's always present. I checked the plugs and wires and nothing seems wrong. Nothing is crossed, plugs are all tight, boots are all tight.
I'm running an MSD Digital 6 with an MSD Blaster coil. Do you think it's possible that I'm getting too much spark voltage and the burn time is much too short?
I dunno what to think really except that maybe I ruined a plug or two already. I've got a set of new factory wires and some new NGK TR6 plugs (one heat range colder, .035 gap) lying around, should I take my chances and spend 3 hours swapping them in?
I'm just frustrated because the car ran like an effin champ before I did this job in preparation for running N20 and now it doesn't.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
The problem is they are too expensive. Most people agree copper is the best. They're cheap and a spark is a spark. Running nitrous, you're going to be swapping plugs a lot anyways. It's possible that a plug is bad, but I would also double check your voltages on vital engine management sensors like O2s, TPS, and MAP.
I have the iridiums on my Ta gapped at .050 ,I have NGK coppers on the z ,the ta idles and accelerates a lot smoother but that could be a bunch of factors though. Although the irridiums did smooth out the ta's idle when I put them in
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
You might want to have the MSD coil tested. Including myself, I know alot of people have had alot of problems with them. Many have had perfectly fine experiences, but alot have had big problems.
