Sponsored by: CARiD
noise from rear when compresed?
Old Oct 14, 2005 | 04:49 PM
The PAT WS6's Avatar
Default noise from rear when compresed?
there is a noise coming from my rear when ever my rear is compressed or when i push on it it is like a creeking noise, could it be a bad shock? the stock ones are on there? or do my edlebrok lca's need to be lubed? i sprayed all ruber bushings with wd40? and that helped nothing,
any help would be great
thanks
Old Oct 14, 2005 | 06:17 PM
Pewterpower's Avatar
Could be. Do the LCA's have zurk fittings on the bushings for grease?
Old Oct 15, 2005 | 12:17 AM
yes they do
Old Oct 15, 2005 | 03:02 PM
Then get a grease gun and grease em up....
Spraying some WD-40 ain'y gonna git er done... :wink:
Old Oct 16, 2005 | 12:37 AM
SporkLover's Avatar
could also be the shock
Old Oct 16, 2005 | 12:47 AM
Trev_SS's Avatar
it probally the LCA's cause the front dont do it and the rear does, they both have the stock shocks on it.
Old Oct 16, 2005 | 01:33 AM
alright mr.goodwrench...
Old Oct 16, 2005 | 02:09 PM
ashzero's Avatar
sounds to me like the sway bar, than the control arms
get under the car, and bounce it by pushing it up. you'll be able to hear where it's coming from.
Old Oct 16, 2005 | 06:15 PM
i tryed that and i cant pin point the noise, how long do stock shocks last?
Old Oct 17, 2005 | 05:10 PM
WestSide's Avatar
I have the exact same noise...i have 100% stock suspension. Let me know if the greasing works for you. Thanks
Old Oct 17, 2005 | 09:28 PM
There is no "greasing" on a stock suspension.
Old Oct 17, 2005 | 09:42 PM
WestSide's Avatar
Then I'm lost.
Old Oct 17, 2005 | 10:28 PM
Originally Posted by WestSide
Then I'm lost.
hahahhaa, how many miles you got on your stock shocks?
i think it could be them bastards
Old Oct 18, 2005 | 05:02 PM
WestSide's Avatar
116k
Old Oct 18, 2005 | 09:42 PM
jimmyblue's Avatar
Moderator
Just go to it one piece at a time if you can't
locate it by ear. But from underneath on ramps
the location should become clear.
Pull the sway bar bushings off and wipe the inside
of them with anti-sieze, asssembly lube (I like the
moly-graphite stuff). Same for the end links.
Old Oct 20, 2005 | 09:40 PM
The official squeak and rattle poem.
Old Oct 26, 2005 | 04:26 PM
should i try replacing bushings? like around the sway bar? i will lube up all zerk fittings and let yall knw
Old Oct 26, 2005 | 06:31 PM
RelentleZ's Avatar
i hate squeaks. nothing annoys me more and my camaro is starting with em. keep us informed
Old Oct 26, 2005 | 07:11 PM
found the problem! its the bushing around the sway bar on the drivers side. can i just buy a new bushing or should i go ahead and buy the energy suspension sway bar with all new bushing. what is the part number for just the bushing? heres a pic
thanks
Old Oct 27, 2005 | 11:16 AM
HandsomeBWouderful's Avatar
LightemUP,
My car makes the very same noise! Did you get somebody to push on the car while you were underneath it? How do you know it is the bushing?
