Sponsored by: CARiD
problems at part throttle
Old Oct 18, 2005 | 07:23 PM
GQ's Avatar
GQ
Default problems at part throttle
so as i start the ol' hawk up and put away this morning, i was greeted with an unfamiliar shutter. It had the feel of a series of misfires, the car would barely move at part throttle, and i could hear it trying. Pushing into it a little further snaps it back into reality and it gets going seemingly unbothered. Until the same part throttle acceleration is applied, then the drag *** game continues. Everything appeared normal under hood, and the car is idling fine. I'm speculating something to do with my fuel filter, or perhaps a bad o2? can anybody confirm my speculation and perhaps narrow it down some with experience. as always thanks in advance. -g
update.. after a day of it being like this and driving periodically i have noticed that it only starts acting up after a few minutes of driving. when the car is first started, regardless of whether its cold or not, it drives normally. if no one has anything, i guess ill hit the auto store this weekend and start the fun process of troubleshooting. -g
Old Oct 19, 2005 | 08:08 PM
GQ's Avatar
GQ
t t t
Old Oct 20, 2005 | 04:00 PM
Ravenous T\A's Avatar
check your ECT (engine coolant temp)sensor, or your air intake temp sensor maybe failing or getting a incorrect reading. if those dont help You may wanna swap out your MAF with a friend and see if that helps and you may want to test your Idle air control module too if that doesnt work. I had some of those same issues with mine a week or so back.
Old Oct 20, 2005 | 08:38 PM
GQ's Avatar
GQ
thanks for the input.. i wish i had someone out here i could swap little things like that. ill see what i can do though. thanks again. -g
Old Oct 22, 2005 | 02:28 PM
half-n-half's Avatar
i have also been thinking fuel filter, or injectors....
i have the same problem wierd part throttle miss and then if you give it enought throttle Bam it is good to go and makes everyone in the neighborhood hate you...
WTF is it?lol
louie
Old Oct 22, 2005 | 03:19 PM
GQ's Avatar
GQ
yea, i was thinking fuel filter as well, ill get around to swappin it along with the oil and a very thorough inspection. I went to get the car scanned yesterday and the only 2 codes i didnt recognize(egr, air removed) was a ckt bank 2 sensor 2 no signal. the same code was pulled twice. I dont know if it is the sensor that is causing the car to run like it is, but is likely. i also wanted to change out the mafs, tps and intake sensor, just to narrow it down a little but once you buy any electronic component, your stuck with it. Which makes troubleshooting a little bit harder. anyone who is not having this problem and is at or near vandenberg cali please let me know. good luck to everyone who is sharing my pain on this one. -g
GQ's Avatar
GQ
Old Oct 22, 2005 | 04:57 PM
http://gearchatter.com/
Look up the codes in here, it will give U a description of what it is and what it does. Look under your year model under DTC codes.
Old Oct 22, 2005 | 08:19 PM
hmmi wonder what ckt bank 2 sensor 2 no signal is...what was teh code do you remember?
Thanks
Louie
Old Oct 23, 2005 | 04:22 AM
ACW's Avatar
ACW
It's good to post the actual code numbers (whether you recognize them or not)...
Old Oct 23, 2005 | 12:28 PM
there is this post as well as the other one both trying to find the seemingly same problem...like i said i will try to get my car scanned and we can all begin to find a common problem amongst all of us and hopefully fix it.
Louie
Old Oct 23, 2005 | 06:24 PM
GQ's Avatar
GQ
p0160 and p0154. sensor ckt no activity bank 2 senors 1 & 2. in the haynes manual it points to the o2 sensor. i have them on order and will put them in when they get in on weds. and let you guys know. -g
Old Oct 26, 2005 | 11:36 AM
1_Bad_LS1's Avatar
Good luck with that...
After talking with half-n-half, I have put the sensors on order as well... Hopefully this is it...
Thanks for all your help guys
