Sponsored by: CARiD
Cooling problems
Old Oct 23, 2005 | 06:29 PM
carzman5678's Avatar
Default Cooling problems
1994 Z28. Its all stock except for a CAI, TB by-pass and airfoil. Automatic.
Lately I have been having a problem with it cooling. I bought the car used and it has a new radiator in it. If I drive a long distance on the highway at 70mph the temperature gauge stays around 180. Stays there alll the time actually so my heater isnt that great. Brand new 180* thermostat and a new 18lbs radiator cap. I am fixing to just go ahead and put a new water pump on this thing. Fans work when the PCM tells them to cut on. My gauge is also correct. Anyone have and input on this? I also have the airdam thing underneath.
Old Oct 23, 2005 | 09:35 PM
97MysticZ's Avatar
What's a Sticky?
So whats the problem? If the gauge is at 180 all the time that is good, thats where it should be.
Old Oct 23, 2005 | 09:51 PM
Camaro 0wner's Avatar
That's actually pretty cool. If the car is running over 225, that's when you might have a cooling problem. 180' should make your car run nice at the track.
Old Oct 23, 2005 | 10:07 PM
Well when i get off the interstate it will overheat for some odd reason.
Old Oct 23, 2005 | 10:21 PM
Empire's Avatar
what does it go up to off the interstate?
Old Oct 23, 2005 | 10:38 PM
It will just rise and rise and rise. I shut it off right before the red.
Old Oct 23, 2005 | 10:41 PM
Nova5's Avatar
170-180 is avereage opertating temp while driving, rises and drops can be expected during stop/go traffic. sounds like the fans don't run. how did you verify the fans?
Old Oct 23, 2005 | 10:47 PM
Fan will cut when sitting and letting it reach Fan temp. I also have tried to cut the defrost on which cuts the fans on.
Old Oct 23, 2005 | 10:54 PM
Quick96ss's Avatar
did you bleed the system before you drove it after you changed the thermostat that might be your problem.
Old Oct 23, 2005 | 10:59 PM
If your car is getting hot when your at a light, or not going fast, it's most likely your fan. When you turn your air conditioning on, does the fan kick on? Have you checked under the hood to make sure it's running? To me, that sounds like the problem since it stays cool while your driving at higher speeds...
Old Oct 23, 2005 | 11:11 PM
Nova5's Avatar
ensure the fan you hear is the radiator fans NOT the cabin fan.
Old Oct 23, 2005 | 11:12 PM
Fan will cut on. Yes I bleed the air out.
