Winter Storage
i am going to be doing an oil change, trans fluid change, and a diff fluid change this saturday. so what about the battery ?? i have read about trickle chargers, does anyone have any specific info on them ??
the car may be driven during the winter months, around my area, in the development, just to start it up and such, but it will go right back in the garage and right back under the cover,
better to leave it be or start it up ?? what about moisture inside the vehicle, a friend of mine has a bucket with a top for such a situation.
what about gas addiditve ??
Fluid changes would be good but I would also get the tranny flushed. All the buildup that gets inside the tranny becomes extremely hard to remove after winter freezes. Get it out before it gets too cold and too hard to get out later.
Every other day I would check the inside for moisture and maybe even start it up to keep the fluids from setting too long, especially the oil. After a month of not starting the engine, ALL oil is in the pan and none is sticking to engine parts. This will cause some minor scaring in the metal. Nothing to worry about but may hurt the longevity of the engine at 100k+ miles.
i would not leave it sit for too long without starting it
Yep, dry gas.
For moisture control, buy a bottle of dessicant (10 lbs or so) and place it in a bucket in the back seat - when it turns white, warm it in your oven (wife permitting) to drive off the moisture and use it again. Type "blue dessicant" into Google images and you'll see what I'm talking about.
Just disconnect the battery - remember or disable your radio code first, though. Start it once a month, warm it up fully, take it up to 3500 just to smile.
I put mine on blocks and double wrapped the tires in Hefty supersacks to minimize oxidation, but I'm doing a longer term thing here. It might be overkill for one season, but if you keep them on, move the car when you start it and don't let them sit on the same patch for 3 months.
Cover it for dust control.
That's about it.
BobP
i might get those tire / wheel "dollies" that have the wheels on them
not wife permitting ( not yet at least ) mom permitting,
the radio, thing is a good idea, better talk to my chevy division tomorrow and get the code,
wash the car. drive it to the gas station - add Stabil , fill tank.
Mines parked in a garage for the winter then... an thats when I work on it. When I'm not working on it, I cover it with a cover , can't remember the brand.
Mine might get heads/cam, clutch,rear end this winter. Look Out!
