TIP, for easy coil pack removal/install passenger side!
I posted this in another thread but I feel its worthy of its own!
To save your knuckles on future engine work:
when you remove the passenger side coil pack, you will discover that the rear stud is a bitch to get to and remove. So once the stud and coil pack is removed, trim the rear mounting hole on the coil pack into a "U" shape.
This way you can fasten the stud back into the valve cover and slide the coil pack mounting hole into the stud. Now for furture removal you will only have back the stud off alittle bit or tighten it a little bit.
This is the where I cut my hands up and it really slowed down the process trying to lossen that stud!!!
thanks!!!
I just cant see leaveing the bolts out like most of you have done!
yes it might not hurt anything but the vibration the coil packs will get from not being bolted down is not worth it! when it only takes a few minutes to do it right!!
Originally Posted by BlackHawk T/A
I thought they were pretty snug still with 3 bolts. I chucked the last one farther than the eye can see.
LOL, i wanted to throw that **** too!!!
