Sponsored by: CARiD
fuel filter
Old Jan 20, 2006 | 07:18 PM
little john's Avatar
Default fuel filter
Getting ready to change the fuel filter,someone told me instead of relieving pressure at the schrader valve I could pull the fuse for the feul pump start the car to relieve the pressure.Anybody done this or is there any harm doing it that way?
Old Jan 20, 2006 | 08:27 PM
1badV6's Avatar
That will work.
Old Jan 20, 2006 | 08:28 PM
1badV6's Avatar
Or you can pull the relay underhood.
Old Jan 20, 2006 | 10:19 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Why bother?
I can't tell you how many times I've changed fuel filters on fuel injected cars without ever "relieving pressure" from the system. It leaks a little fuel when you pull the line off, but it's not like it sprays everywhere....no big deal if you ask me. But I usually do those sort of swaps after the motor is cold, maybe it's a different situation if the motor has just been running?
Old Jan 20, 2006 | 11:25 PM
2001whiteSS6spd's Avatar
I have changed hundreds of filters, I have never done anything to releive the pressure. Just put a drain pan under the fuel filter and remove and reinstall new one.
Old Jan 21, 2006 | 12:49 AM
ninetres's Avatar
I followed install universitys directions because it was my first time on my new car, and when I bled the schrader valve, it didn't even spray one bit.....maybe ONE small DROP leaked on the rag (when I blinked or something) if anything at all. I figured it would spray everywhere according to all the rags they have you wrap a screwdriver in, but next time I'm just pullin the filter out.
Old Jan 21, 2006 | 03:46 AM
spy2520's Avatar
i relieved pressure on my last car and it leaked a little still, from that experience i guess it is bound to leak a little no matter what so its probably not necessary to bleed or relieve the pressure.
Old Jan 21, 2006 | 05:51 AM
02RedWS6RamAir's Avatar
Just changed mine a couple of days ago. Simply took off the old one and put a new one on, leaks a little bit. As above stated, just put a a drain pan under the car and your fine. It's one of those jobs that that kinda sucks in that you will end up smelling like a gas station.
Old Jan 21, 2006 | 08:11 AM
davered00ss's Avatar
Moderator
You need to do both. check the instructions @ installuniversity.com
Old Jan 21, 2006 | 09:05 AM
RPM WS6's Avatar
No need to do anything but R&R the filter.
This is probably one of the easiest and most straight forward maintenence tasks you can do on these cars. It's just about as simple as putting gas in the car.
Old Jan 21, 2006 | 09:44 AM
Moderator
If you want to get sprayed with gas. I got that **** in my eye once. I relieve the pressure now.
Pull the fuse & release the pressure from the shranner valve.
Old Jan 21, 2006 | 11:48 AM
RPM WS6's Avatar
Done more filter swaps than I can count. Never once sprayed with gas. It just drips out a little bit when you pull the line, just don't be right under it, no biggie.
EDIT: If the motor was just running, then I could see some pressure still being in the system. But if the motor has been off for a few hours, and fuel actually sprays out of the line under pressure when you pull the filter, you've got one HELL of a fuel system.
Old Jan 23, 2006 | 06:05 PM
I bled the schrader,as said no gas even came out.Thanks for the replies,just didnt want gas all over the motor.
Old Jan 23, 2006 | 08:19 PM
Z28LS1camaroguy's Avatar
how much does it cost to get the fuel filter changed?? i have like no spare time to do this and i think its the reason for an idle issue and bad gas mileage. I have a friend who works at goodyear who changes my oil and all that all the time and since i will be taking my car in to change the oil i was wondering how much I should expect to pay for a new fuel filter.
Old Jan 23, 2006 | 09:36 PM
Pewterpower's Avatar
It takes about as long as it did for you to sign into this website and post this question...
Old Jan 23, 2006 | 09:51 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Question
..10 times I have done this probably--I open gas cap,then........I change the damn filter. Why are you guys doing anything else.??? Why make a purely simple 10 minute job into a "MAJOR OPERATION".???
Old Jan 23, 2006 | 10:11 PM
slowpoke96z28's Avatar
why open the gas cap?what kind of fuel pump do you have?
Old Jan 24, 2006 | 05:14 PM
RPM WS6's Avatar
Does it really even take 10 minutes? Seems more like 5 or less to me.
Old Feb 7, 2006 | 11:36 AM
john shea's Avatar
Changed mine and didn't relieve anything.
Don't smoke while doing the filter change.
Old Feb 7, 2006 | 04:28 PM
waiting2bl33d's Avatar
removing the gas cap will relive pressure in tank not in the fuel system. i've always been told to just open the gas cap and take them off on the camaro and on the DSM dripped alittle gas but thats it. just remember after you do it the car wont start "right" up you will have to let the fuel get back up to the rail
