turn signal problems
-Most likely not flasher unit if the other one works, but it is possible
If you swapped out the bulbs, check to make sure it's in the right way. They appear as if they can go in any way, but they don't; you can have them spun 180* off. While you're checking the bulb, make sure it's not burned out. If the bulb checks out ok, may have to have to replace the socket.
If it was a bad blinker, both sides would be affected.
