Bent pushrod Maybe?????
just pull them all and replace them.
Can I just remove the coils, the covers, the rockers and pull them out? It looks so tight under there...
How bad is to drive with bent pushrods? Is there something I could damage?
Should come right out, i had no problems removing mine at all. The pushrods arent very long,
I'm asking about pushrods because I have a noise, especially during cold starts. Like a clack clack clack that goes with the engine speed.
I was thinking it may be a bearing of a connecting rod... but those usually sounds really bad. Much worst than now.
It starts from about 1000 rpm, after 3000 the noise is gone.
I hear that noise only when there's load on the engine: at idle and checking with a stethoscope I hear nothing, it's just under load.
I see no misfire, LTFT's B1/B2 are the same, no codes.. strange.
Is there a way to know it's a pushrod without removing parts?
