Sponsored by: CARiD
low oil light is on
Old Mar 5, 2006 | 03:19 AM
dans2k1ws6's Avatar
Default low oil light is on
low oil light is on so i checked my oil and it was low but i just change
my oil 1000mi ago so why would it lose oil so fast maybe the cam?
let me know
thanks
Old Mar 5, 2006 | 04:25 AM
89tang's Avatar
No it's not cause of the cam, your burning or leaking oil somewhere. Time to figure out what it is. Could be a bunch of things, valve seals, piston rings, valve cover gaskets leaking, oil pan gasket.
First is it smoking start up or smoking on acceleration or deceleration? Plugs clean? How low was it? Correct me if i'm wrong but you'd have to be pretty low for the dummy light to come on don't you? I know our TA burns the normal quart between changes and i've never seen the dummy light come on.
Old Mar 5, 2006 | 06:32 AM
dans2k1ws6's Avatar
under the <XXmakesxx============================={)
Old Mar 5, 2006 | 06:34 AM
dans2k1ws6's Avatar
no leaks in my driveway
Old Mar 5, 2006 | 07:11 AM
davered00ss's Avatar
Moderator
Low Oil Light comes on when you are 2qts down.
Old Mar 5, 2006 | 08:05 AM
SSJIMMY's Avatar
I think the light comes on when you forget to reset it after changing the oil. It did the same thing to me last time and I just reset it.
Old Mar 5, 2006 | 10:30 AM
Moderator
That's the Change oil light.
Old Mar 5, 2006 | 01:47 PM
89tang's Avatar
AHHHHHHHHHH the change light yeah i forgot about that damn these newer cars. Sorry about getting ya worried
Old Mar 5, 2006 | 02:26 PM
'Trust''s Avatar
How many quarts did you fill up with when you did the change? Burning 2 quarts in 1000 miles is alot of oil. My block is porous and i dont leak that much. You can pull of your TB and see if it has oil on the backside of it.
Old Mar 5, 2006 | 03:51 PM
89tang's Avatar
Maybe he didn't put enough oil in it? Possibly a combination of the oil light being on for the oil change and not putting enough oil in it when he changed it?
Old Mar 5, 2006 | 05:51 PM
dans2k1ws6's Avatar
im not sure how many quarts thay put in. had it done at pontiac delership
so how many quarts? go in many way
Old Mar 5, 2006 | 06:24 PM
KrazyDan's Avatar
ls1's take 5 1/2 to 6 qrts depending on your filter
Old Mar 5, 2006 | 06:39 PM
Sgt. Spuds's Avatar
Shirley Temple Drinker
What do LT1's take? Sorry for the hijack.
Old Mar 5, 2006 | 06:47 PM
99camarosupersport's Avatar
it should be in your owners manual if you have one. you've had your car for a while haven't you has it never been changed, or has someone else done it for ya ?
Old Mar 5, 2006 | 08:26 PM
blue01ta's Avatar
The PCV perhaps?
Old Mar 5, 2006 | 08:40 PM
Speed Density's Avatar
hashtagBMW
Damn, that was good. Spud have you changed your oil?
Old Mar 5, 2006 | 09:46 PM
Sgt. Spuds's Avatar
No I have not...
I have never done it, and got the info I need pretty much. Instead of paying some grease ball 60 bucks I told myself that I am gonna just do it myself. Going to use mobil 1 10w30 and a acdelco filter... Gonna do it over spring brake.
Old Mar 5, 2006 | 09:50 PM
1994Z28Lt1's Avatar
5 qts in the lt1 with the standard filter brings you right up to the full line on the dipstick if you use the longer truck filter, 5 qts should bring you half way between the add and full line
Old Mar 5, 2006 | 10:30 PM
Sgt. Spuds's Avatar
THANKS
[/highjack]
Old Mar 6, 2006 | 02:11 AM
dans2k1ws6's Avatar
What’s the worst ting it could be?
