02 sensors went bad got a quick ?
ok my sensors went bad i had the code read and its the back sensor..soo should i get new sensors at 80$ a piece or get the 02 sensor mock up...or shoudl i not worry about it??? and i was wondering if there was a cheaper place on the net than 80 a piece
Try these
http://www.afterthoughtsauto.com/o2sim.html
If the SES light doesn't bother you, just leave the back ones in there (if you can find someone with hptuners/efilive, they could delete the codes for you)
The only bad thing about leaving the ses light lit is you won't know if you have another problem
There's no need to replace those b/c the only purpose they do is tell the PCM if your cats are ok. There's no performance loss with them being unplugged. I wouldn't replace them b/c you'll be waisting money for no reason. If you can handle having the SES light on, leave them alone and get a tune to delete them permanently.
awesome i think i will do that instead.....now what would happen in the future if i went with headers and a ory pipe on a 1999 z28? with the 02 sensors and the ses light
If you do headers you may set the SES light, due to the fronts having insufficient switching, many times this can be solved by using the vette rear o2s (bosch 13111) they have a better heater than the f body o2s, and can often help with the insufficient switching problem
ok this is kinda wierd but the ses light went off and now im not throwing any codes??? lol wondering if all this rain we have been haveing is the problem...ohh well dont need to spend the money now
