Sponsored by: CARiD
Got my LS1, help plz
Old Mar 12, 2006 | 07:39 PM
ironexecutioner's Avatar
Default Got my LS1, help plz
Ok, I just picked up my ls1 from TN. I love everything about it its so nice. 2 things I am having a problem with though. 1st is my cruise control. This is a 98 Trans Am WS-6. The cruise control is located on the side of the turn signal. When I go to activate it, it doesn't work. Wondering what this could possibly be and possible fixes. The second thing is the vent cluster on my controls does not light up when I turn my lights on, although everything else lights up appropriately. I find it very difficult to believe that GM would produce the vehicle without lighting for that.. so what could the problem be? I checked my fuse panel and looked at the "Guages" fuse and the "A/C Cruise Control" fuse and they are both fine.. any others I should check? What could my problems be and what kind of difficulty can the fix be? Thanks
Old Mar 12, 2006 | 07:52 PM
BLUE99T/A's Avatar
For the cruise control I would first check under the hood to make sure your cable is connected to the throttle body. If that is good then buy a chilton and use the wiring diagrams to trace the wires with a multimeter. Then buy a cruise control pump(not sure exactly what its called).
Are you sure you're doing it right? Not being a smart ***, just checking.
Old Mar 12, 2006 | 08:31 PM
according to the instruction manual i am. There is also a good bit of obvious wear on the turn signal at the cruise control section, being that it no longer even says "cruise control" its completely worn off except for a smiggen of white. I had to look in the book to see where it was.
Old Mar 12, 2006 | 08:51 PM
mrhzk35404's Avatar
sounds like you have some bulbs burned out.
Old Mar 12, 2006 | 09:57 PM
ls14pwr's Avatar
Is it an m6 car? If so try to use this thread
https://ls1tech.com/forums/showthrea...cruise+control
If not try this one
Hope this helps.
Old Mar 12, 2006 | 10:37 PM
2002_Z28_Six_Speed's Avatar
Is it even still in the car? A lot of people take them out. See if the CC module is still installed on the left side of the car, very low on the frame rail.
Old Mar 15, 2006 | 10:37 AM
turbols1_05's Avatar
You have a TA What do u need cruise control for,drive that damn thing
Old Mar 15, 2006 | 08:18 PM
I took mine out. I don't really miss it. Extra weight.
