Sponsored by: CARiD
y-pipe
Old Mar 30, 2006 | 10:53 AM
freshduckie's Avatar
Default y-pipe
Do I need a new y-pipe if I replace my catalytic converters on my 01' ws6?
Doug
Old Mar 30, 2006 | 07:36 PM
Camaro_SS's Avatar
You replacing them with OEM-sized? Or going with aftermarket?
NEED MORE INFO!
Old Mar 31, 2006 | 06:10 AM
Well I was not going to put a cat-back on at this time but later. I think one of my cats is clogged so I need to change those out and was just wondering if I had to change the y-pipe as well. If I don't have to I won't change the y-pipe unless I can find one cheap that will give performance boost. If I was to change it I would go aftermarket.
Thanks
Old Mar 31, 2006 | 09:14 AM
Camaro_SS's Avatar
Thanks
If you are sticking with OEM cats then no, you don't need to change the y-pipe. However, if you are thing of aftermarket pipes, then drop the change for long tubes, cats and y-pipe. "cat-back" for F-bodies typically means from the y-pipe back, because the cats are mounted in front of the y-pipe.
Old Apr 3, 2006 | 06:54 AM
What about if I am going to put on aftermarket cats, but no headers. Do I need a new y-pipe?
Old Apr 3, 2006 | 01:10 PM
Camaro_SS's Avatar
No, if the aftermarket cats fit in the original location. Make sure you keep this in mind when looking. Many aftermarket cats are a "bullet" design, and aren't made to fit in the stock location.
Old Apr 7, 2006 | 11:34 AM
Has anyone replaced stock cats with Magnaflow Carsounds unverial cats 94100 series?
Thanks
Old Apr 8, 2006 | 03:47 AM
Camaro_SS's Avatar
Not if you are keeping your stock headers!! The stock cats are bent at the inlet tube, and have their flanges welded on. Again, if you want to go with aftermarket cats, then you'll have to go with aftermarket headers. Unless you want to fabricate connecting tubes and flanges, that is.
Old Apr 10, 2006 | 11:34 AM
Thats a bummer, thanks
