Overheating - solved... You'd never guess how
https://ls1tech.com/forums/generation-iii-external-engine/375528-overheating-question.html
Anyway, 4 weeks ago I took my heads off because I thought I had blown head gasket(s). I didn't, they were perfect. But what I did find was burnt oil built up on every piston from my completely shot valve seals. It was so bad that some of the valve reliefs were completely filled in. I cleaned them like new.
I installed the new heads and then realized a crack in my radiator, so I pulled it out to replace it. In doing this I looked at my A/C condensor, it was packed so heavy with debris that almost no air could pass through about 50% of the surface fins. The **** wouldn't come out with a spray of water from my hose so I figured I'd just say screw it and buy a new condensor. The next day after it was dry I got mad and grabbed it and slammed it against the frame of the car and everything fell out of it. There was a pile of little rocks, grass and other crap all over the ground under it. I banged it hard against the frame about 50 times and it was pretty much like new. Amazing fix, eh?
Now I can blast the A/C in heavy traffic, like I did the past three HOT *** days in Lauderdale and in Orlando. It never detonates anymore and it doesn't even get hot. The detonation was obviously from all the burnt oil build-up on my pistons and causing hot spots and pre-ignition. Also, from what I've been told, the condensor got hotter than normal and that hot air went right through the radiator. And the radiator was also being deprived of alot of air because the condensor was so clogged up. I guess when I turned the A/C on it was just too much and put it over the edge.
I guess after 8 years a condensor will get clogged up with crap.
Oh well, thought this may help someone else find the little gremlin that is causing an overheat condition, when everything else checks out fine.
Later,
I had an IROC, that would suck up plastic bags, leaves, and other assorted crap, it became part of my yearly spring maintenace to clean out the crap trapped between the condenser and radiator
And no it never went off road
Maybe someone that has gone through every single troubleshooting item and still can't figure it out will also have a clogged condensor. Because noone ever brought that up.
I think the burnt oil build-up on the pistons contributed to the overheating. I think when I turned my A/C on it will normally make the engine hotter, but mine started to detonate way before it should have, so maybe it helped heat the heads up.
I had some kind of plastic melted to the radiator..
The tech told me it was a bitch to clean but it did solve the overheating issue last summer..
Congrats and thanks for posting this for others..to have an easier time of it..
Glad you found the prob.
