Sponsored by: CARiD
replacing temp sensor
Old Jun 17, 2006 | 06:34 PM
z28_n_tx's Avatar
Default replacing temp sensor
it might seem dumb , but i can t figure out how to get the old one out. i cant use a socket or wrench, its too close to the header and theres not enough room for either tool to fit.
Old Jun 17, 2006 | 06:47 PM
Low N Slow's Avatar
Have you tried a crowfoot? If it's too close for one you might have to loosen the header and pull it away from the head a little ways.
Old Jun 19, 2006 | 09:47 AM
REDWS6ROCKET's Avatar
a 19mm wrench or 3/4 wrench will work, i have done it many times, make sure you have a bucket you will lose coolant
Old Jun 20, 2006 | 11:37 AM
z28_n_tx's Avatar
i finally got it out...it seems like the old sensor had thread lock...do i need to put some on the new one?? the damn instructions say not to use any grease but nothing about thread lock??
and would i need to reset my car after replacing the sensor? or will a code just go away on tis own...it was throwing a P0118 code
Old Jun 20, 2006 | 02:50 PM
z28_n_tx's Avatar
any input??
Old Jun 20, 2006 | 08:14 PM
waterbug1999's Avatar
I know when I replaced mine (broke it during the header install) I just unplugged the battery and it was fine.
But, I tried 2 off brands (from napa & autozone) and they did not work for some reason. So, I went to GM (I think it was a AC delco brand) and put it in and it worked fine.
Old Jun 20, 2006 | 11:46 PM
z28_n_tx's Avatar
you mean the sensor you bought at auto zone and napa didnt work??? i bought mine at autozone replaced it tonight..drove the car to autozone and the damn code is still there...any one what it could be??
Old Jun 21, 2006 | 11:57 AM
Go post your code in the diagnositc section, im sure you will get it in there fairly quick.
Oh, and yea, the autozone one didnt work..
Old Jun 21, 2006 | 03:22 PM
Shallow Bay's Avatar
How many times have you started the car since you replaced the sensor? I ask this because the control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
Old Jun 21, 2006 | 06:37 PM
z28_n_tx's Avatar
a few times..dont really know for sure. but i will be reseting the pcm again and hopefully that will do it.
Old Jun 21, 2006 | 09:31 PM
G-Body's Avatar
sawzall wielding director
If you stop by autozone tell them you bought the sensor and still have a check engine light. Have them pull the codes and delete it, if it comes back then you have a problem with the new sensor or mabey the wiring.
Old Jun 21, 2006 | 11:05 PM
z28_n_tx's Avatar
see thats the thing, the SES light only came on the frist couple of times i started the car after header install. but i had forgotten to plug back in the wiring to the sensor. this was last thursday, ofcourse i plugged it back, but since friday i have not had the SES light on. But i still went in that same day to get it scanned to see why it came on to begin with.
